| Weird cabinet resonance issue!
Hi guys
So I've just set up my new Alphason stand (Ambri ABRD1100-B) & am having an issue with resonance from my Sky+ HD box & my PS3... need some advice!
The stand has a lower cabinet with a door which holds 2 x pieces of kit, and you can also place a 3rd item (PS3 in this case) on the top.
So I've put everything in, and am getting a really annoying low humming sound from the cabinet when the Sky box or PS3 is on, which I'm guessing is the hard drive causing a resonance inside the closed part of the cabinet. I know it's this issue as if I lift either up the noise stops, and if I open the cabinet door the noise stops. The back of the cabinet is closed in except one small-ish hole for the cables.
I am thinking I could make the hole larger in the back to open it up, but I really don't want to start cutting the cabinet as it's brand new. I would prefer to find something that I can put under the PS3/Sky box which will effectively stop the resonance from transmitting from the equipment to the cabinet.
Does anyone have any suggestions, or has cured this issue in the past?
Thanks!
