Low , Narrow TV Stand/Cabinet
Old 14-11-2009, 8:36 PM   #1
3,427, Level: 13
Points: 3,427, Level: 13 Points: 3,427, Level: 13 Points: 3,427, Level: 13
Hello All,
I have been looking for a tv stand/cabinet for months, but cant find the right one.
The max dimensions are:
Height : 40cm max
Depth : 35cm max ( this measurement is fixed, it cannot be deeper)
Length : around max 100cm
We are open to finishes, but the main theme in our living room is solid oak but we are also open to glass/stainless steel ( no chrome) if the finish is good.
We are quite taken by the cabinets sold here, but too deep unfortunately
Milan LCD and Plasma TV Support Range - customdesign.co.uk :
Any suggestions?
Much appreciated
Old 16-11-2009, 10:49 PM   #2
922, Level: 6
Points: 922, Level: 6 Points: 922, Level: 6 Points: 922, Level: 6
Re: Low , Narrow TV Stand/Cabinet
Similar problem for me as well.
Have been trawling through the web for low height TV stand for 42" TV. The height of the stand has to be between 40cm and 45cm
Any suggestions anyone?
Old 20-11-2009, 7:46 PM   #3
3,620, Level: 14
Points: 3,620, Level: 14 Points: 3,620, Level: 14 Points: 3,620, Level: 14
Thanks: Gave 0, Got 22
Try our advanced search Set as follows
Product type > TV Stand : Product width > 71cm to 100cm : Product depth > 40cm or less : Product height 50cm or less
you will find some glass and wood finish stands in the selection, you could also modify the search to find different products.
Old 20-11-2009, 9:21 PM   #4
2,171, Level: 10
Points: 2,171, Level: 10 Points: 2,171, Level: 10 Points: 2,171, Level: 10
Hey Kierangray1982,
The Custom Design Milan Range are a very good choice! English Company, English Product! Enough said!
From experience I know you will struggle to find an AV Stand or TV Stand Manufacturer that makes a stand 35cm deep (unless you go for a cantilever TV Stand). The standard seems to be 40cm I suspect this is due to the depth of most AV kit eg: DVDs, Amps ETC.
How big/heavy in the TV and kit to be?
Had you thought about getting something custom made?
J
Hey jonthiru,
The product above is the Milan range but key things with this product is the side supports are available in different heights!! (Costs more tho but that's something to be looked into later if you want to). If you have the 200mm shelf spacings you would not be able to have the cable management system.
Also the XS Milan (the one in the link) is available with a centre wooden support between the bottom and middle shelf too. I would recommend this as the glass is only 6mm and only really supports 15-20 kg per shelf. The top shelf is 10mm so a 42" TV should be fine!
Hope this helps.
J
Old 22-11-2009, 12:30 PM   #5
tonyrees687's Avatar
3,336, Level: 13
Points: 3,336, Level: 13 Points: 3,336, Level: 13 Points: 3,336, Level: 13
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 94, Got 84
You can try these guys http://www.eatsleeplive.co.uk/chunky..._tv_stand.html
I had this stand made to my dimensions iam thrilled with it a real solid bit of kit
Mark the owner will make up any size or style for you and he a good chap as well
Regards Tony
PS iam not that great at photos
Low , Narrow TV Stand/Cabinet-s8002352.jpg   Low , Narrow TV Stand/Cabinet-s8002351.jpg   Low , Narrow TV Stand/Cabinet-s8002350.jpg   Low , Narrow TV Stand/Cabinet-s8002349.jpg   Low , Narrow TV Stand/Cabinet-s8002348.jpg
Old 22-11-2009, 9:22 PM   #6
2,479, Level: 11
Points: 2,479, Level: 11 Points: 2,479, Level: 11 Points: 2,479, Level: 11
Thanks: Gave 0, Got 4
This is one I am currently concidering, although probably a darker finish than the rest of your furniture.
Denver Low TV Unit - Easy Living Furniture
Also John Lewis have a couple of units
http://www.johnlewis.com/230606138/Product.aspx
http://www.johnlewis.com/230630290/Product.aspx
All 3 are 36cm deep so if there really is not an extra CM probably no good.
Old 23-11-2009, 4:50 PM   #7
1,049, Level: 7
Points: 1,049, Level: 7 Points: 1,049, Level: 7 Points: 1,049, Level: 7
This is mine from argos not everyones cup of tea and is in beech not sure what else they do.
Buy Cubes Oak Finish TV Entertainment Unit. at Argos.co.uk - Your Online Shop for .
with one of these at either side Buy Cubes End Table. at Argos.co.uk - Your Online Shop for .
the height of it all is 30cm, depth is 40cm and the width of the tv stand is 90cm the entire length of my setup with the two end tables is 170cm.
Matt
Old 24-11-2009, 10:07 PM   #8
922, Level: 6
Talking Awesome
Thanks guys.
There are some really nice pieces of essential furniture recommended.
The missus is paying a very close attention. Got to match the curtains, if you know what I mean.....
Old 26-11-2009, 9:49 PM   #9
stevogums's Avatar
3,304, Level: 13
Points: 3,304, Level: 13 Points: 3,304, Level: 13 Points: 3,304, Level: 13
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 23, Got 7
Matt
They would be ideal in black..
Old 28-11-2009, 10:19 PM   #10
3,427, Level: 13
thanks very much for your responses to my thread.
Im still looking, possibily going down the route of custom made to get an exact fit.
Ill let you know what i decide
Old 06-12-2009, 3:34 PM   #11
4,350, Level: 15
Points: 4,350, Level: 15 Points: 4,350, Level: 15 Points: 4,350, Level: 15
Activity: 1.0%
Thanks: Gave 10, Got 86
Some nice cabinets in this thread - cheers.
This is my "temporary" one, it was supposed to only be until I found something else (don't worry, the radiator IS off).
Crap photo, I know, just wanted to give you the idea. As you can see, it collects dust like...
It's two Ikea Lack benches mated together.
IKEA | TV solutions | TV solutions for tube TVs up to 25'' | LACK | TV bench
Spare top is being a shelf somewhere else.
Low , Narrow TV Stand/Cabinet-img_3044.jpg
Old 14-12-2009, 1:51 PM   #12
jimmyboy1975's Avatar
3,007, Level: 12
Points: 3,007, Level: 12 Points: 3,007, Level: 12 Points: 3,007, Level: 12
Activity: 6.8%
Activity: 6.8% Activity: 6.8% Activity: 6.8%
Thanks: Gave 97, Got 69
Nice idea Cafe Racer, I was also looking at this but realised it was too low, never thought about sticking 2 together - how are they held together??
J
Old 22-12-2009, 12:26 PM   #13
4,350, Level: 15
Activity: 1.0%
Sorry for the delay.
The units are typical Ikea - couple of dowels and a couple of cam-lock things, and the holes are usually roughly in the same place.
What I did was take the base from one and re-drill the underside (maximum of 4 holes, can't remember) so that it matched the underside of the redundant top, and the redrilled base became the middle shelf. If that makes any sense.
Old 22-12-2009, 3:19 PM   #14
4,350, Level: 15
Activity: 1.0%
Oh, and Kieran - would 360mm be okay?
Buy John Lewis Stowaway Finished Long TV Unit online at JohnLewis.com
