Iconic UKGL 411-BL Cantilever 90cm Glass TV Stand
Old 10-11-2009, 7:01 PM   #1
2,048, Level: 10
Points: 2,048, Level: 10 Points: 2,048, Level: 10 Points: 2,048, Level: 10
I am currently looking for a small cantalever stand to hold my 42" Panny and speaker, dvd, HD recorder, video player etc.
Has anyone bought a Iconic UKGL 411-BL Cantilever 90cm Glass TV Stand. The size sounds ideal but will I be able to get two full size units between the legs. (I am planning to put my speaker on the top shelf).
Paul
Old 12-11-2009, 11:06 AM   #2
2,048, Level: 10
Re: Iconic UKGL 411-BL Cantilever 90cm Glass TV Stand
As it would appear that nobody has experience of this stand can anyone recommend a small <100cm cantalever stand with one or two shelves?
Each shelf needs to hold two full size boxes side by side and there needs to be room for a centre speaker on the top under the screen.
Paul
Old 12-11-2009, 2:04 PM   #3
1,675, Level: 9
Points: 1,675, Level: 9 Points: 1,675, Level: 9 Points: 1,675, Level: 9
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 1, Got 51
You should be OK with a centre speaker but you will not fit two full width Hifi units on there, the stand is only 900mm in width and two full size units measure 880mm without space for ventilation, and the stand has legs which eat into that space, you will need a wider stand like the Aquila FAV-S193B, it is currently out of stock until mid December however.
