Help finding a certain type of cabinet
Old 04-11-2009, 11:10 PM   #1
5,550, Level: 17
Points: 5,550, Level: 17 Points: 5,550, Level: 17 Points: 5,550, Level: 17
Activity: 3.8%
Activity: 3.8% Activity: 3.8% Activity: 3.8%
Thanks: Gave 39, Got 49
I hope I'm posting this in the right section ..
I'm after a cabinet quite similar to this http://www.ikea.com/gb/en/catalog/products/90144730 , but not quite as wide, but can't seem to find one. Any suggestions?
Old 05-11-2009, 9:39 AM   #2
3,794, Level: 14
Points: 3,794, Level: 14 Points: 3,794, Level: 14 Points: 3,794, Level: 14
Thanks: Gave 48, Got 27
Re: Help finding a certain type of cabinet
May want to try the Furniture forum. You could have a local carpenter make your cabinet to specific size if you can't find a ready made one.
Old 05-11-2009, 10:29 PM   #3
5,550, Level: 17
Activity: 3.8%
Sorry I didn't realise there was a furniture section, thanks to whoever moved it
I *may* be able to make do with the one I posted in the link above, but ideally I'd like a smaller version of it. Looking at the price, £29.90, how sturdy is that likely to be?
I bought a small cabinet for CD/DVD storage from Argos a few years back for something like £15 and you're only to touch the top of it and it'll sway from side to side
Old 06-11-2009, 2:54 PM   #4
3,794, Level: 14
Are you putting a TV on top or is this for storage only? How big is your TV or more importantly how heavy?
Old 06-11-2009, 9:27 PM   #5
5,550, Level: 17
Activity: 3.8%
No, my TV's on the wall. It'll be used for storage only (Sky HD box, PS3 & DVD player)
