Go Back   AVForums.com > Other Home Cinema Essentials > AV Stands, Cabinets, Seating and Furniture
Today's price checkPowered by
The Furniture Factory Worcester TV Entertainment Unit
John Lewis Maharani Corner TV Unit
John Lewis Stowe TV Unit
John Lewis Matilda Bar Chair, Black
The Furniture Factory Worcester TV En...
Ellis Entertainment Unit, Light
McCord Lynx TV Entertainment Unit
Solo Flatscreen TV Entertainment Unit
Town House countryman long TV enterta...
Balmoral TV entertainment unit
Vader TV entertainment unit
 More...Prices updated November 21st at 10:30pm and include delivery.
For Sale : CHEAP 3 NETWORK PHONE FOR £20 DELIVERED TooDark Mobile Phone Classified Adverts 31 14-11-2009 3:36 PM
Wanted : Cheap floor standing speakers Incrediboy Speaker and Subwoofer Classified Adverts 16 30-10-2009 5:57 PM
Yamaha RX-V765 Alternatives - Suggestions? Alphathon AV Amplifiers and Receivers 0 27-10-2009 9:28 PM
Cheap but (is it) Cheerfull Demolition man Camcorders and Video Editing 8 27-10-2009 7:48 PM
Old 28-10-2009, 1:37 AM   #1 (permalink)
AndyCob's Avatar
Thanks: Gave 31, Got 109
Cheap alternative to Quadraspire QAVX stand?
HI,
Need help, I have been looking for ages for a 3 unit wide 3 shelf stand capable of holding a bunch of very large heavy units and so far the only thing I have been able to find in the UK is the Quadrspire QAVX see here:Quadraspire - AV Racks / AV Stands / AV Furniture / TV Stands / Plasma Stands
Just to give an example on the size weights for the bootom shelf would include (WxHxD)cm:
43x24x55 20-30Kg
43x21x44 20-30Kg
43x20x36 15-20Kg
Middle nothing special three vcr size wieght units
Top 55Kg TV
Unfortunately a quick spec up of the QAVX gives a price of £1,050 which is just way to much.
I have found the much more reasonably priced and better looking IMHO StudioTech HF-33 here:Plasma Component Racks | HF-33 | Audio Video Furniture | AV Furniture
Only $500~£300 but of course it's only available in the USA and at 93 pouds in weight isn't really economical to ship.
So anyone know anything similar that's UK available?
Sony - TV:KDL-55X4500 BD:BDP-S550 (MZ/MR) DVD:DVP-CX777ES (400 disc changer, PAL/MR mod US Import) VCR:SLV-SX800 AMP:STR-DA5200ES SPKRS:SA-VS300H (7.1) PHONES:MDR-DS3000 (Digital infra-red surround) TAPE:TC-KB820S PC:VGC-RM2U PC-MON:SDM-HS95PRB - Sony victim aren't I. SkyHD (1TB)
AndyCob is offline   Reply With Quote
Old 28-10-2009, 12:06 PM   #2 (permalink)
Assured Advertiser
paul@big-av's Avatar
Thanks: Gave 0, Got 14
Re: Cheap alternative to Quadraspire QAVX stand?
Take a look at the BDI Deploy Max range-
They quote the bottom shelf is capable of supporting 68kg but BDI are usually conservative with their recommendations, there is also the Spectral PL182-
This stand is avaialble with or without a cantilever bracket, the glass colour and the shelf heights are customisable, the price of these units is between £600 and £800 depending on the exact specification.
I will try and source some other options for you, if I find anything I will let you know.
Best regards
www.big-av.co.uk TV Stands, HiFi Stands and AV FurnitureSuperstore. Price Match Promise.
email: sales@big-av.co.uk
Tel (furniture) - 01484 420088 / 01138151535
(electricals) - 01484 439030
Last edited by inzaman; 28-10-2009 at 12:58 PM. Reason: Image breaks forum rule no. 9
paul@big-av is offline   Reply With Quote
AndyCob (28-10-2009)
Old 28-10-2009, 9:13 PM   #3 (permalink)
AndyCob's Avatar
Cheers Paul,
Have looked at the whole BDI range and it's a case of so close but not quite.
The space is a bit tight, in fact the depth is way over but I might get away with it if I left out the back board but can't tell without knowing the spcing of the back braces. However I'm well over on the weight, I actually edited my post downwards as it seemed to much, I'm sure I estimated a combined weight for the 3 things on the bottom self of 66Kg. The BDI Deploy doesn't have enough shelf height, the Icon does but only takes 45Kg on the bottom (Icon 9428/9429), though I would probably get away with the overload (maybe) it's also £700. Both the StudioTech and Quadraspire can handle over 100Kg+ per shelf so no issues there. I really want the StudioTech it's the right design/price $500~£300 but not available in the UK.
Thanks.
Old 03-11-2009, 1:20 PM   #4 (permalink)
Assured Advertiser
Have you seen the BDI Deploy 9629 and the BDI Deploy 9639, these ones have a height adjustable middle shelf so I think these might do the trick for you.
Old 03-11-2009, 3:06 PM   #5 (permalink)
AndyCob's Avatar
Yep seen the deploy I even emailed to find out what heights the adjustable shelves could give and it's not enough, seems a 24cm high component is just to big. Plus the depth is still an issue to because the back is not open, I don't actually need a 50cm+ deep shelf because the unit can hang out the back but with leads etc it's probably going to be 55cm+ and the BDI shelf depth is only 44cm. One of the reasons the Quadraspire and studiotech design solves that problem. If the StudioTech was available in the UK I would have bought it already but I'm not paying a £1000+ for the Quad.
Old 03-11-2009, 9:04 PM   #6 (permalink)
Assured Advertiser
Leave it with me I will contact Quad and see if I can help you out.
Old 04-11-2009, 4:09 PM   #7 (permalink)
AndyCob's Avatar
Ok thanks, though don't put yourself out, I really didn't want to spend more than £500 and I can't see Quad doing a 50% discount.
If it wasn't so heavy (93 pounds), big and expensive to ship I would try and get a StudioTech stand freight forwarded from the US.
alternative, cheap, qavx, quadraspire, stand
