Go Back   AVForums.com > Other Home Cinema Essentials > AV Stands, Cabinets, Seating and Furniture
Today's price checkPowered by
The Furniture Factory Worcester TV Entertainment Unit
John Lewis Maharani Corner TV Unit
John Lewis Stowe TV Unit
John Lewis Matilda Bar Chair, Black
The Furniture Factory Worcester TV En...
Ellis Entertainment Unit, Light
McCord Lynx TV Entertainment Unit
Solo Flatscreen TV Entertainment Unit
Town House countryman long TV enterta...
Balmoral TV entertainment unit
Vader TV entertainment unit
 More...Prices updated November 22nd at 8:30am and include delivery.
Which Receiver for MA RS Series bbasra AV Amplifiers and Receivers 20 26-10-2009 12:14 AM
Vertical stand for PS3 slim? gaz847 PS3 27 21-10-2009 3:22 PM
Where do i stand ? paul r s78 Sky HD 7 10-10-2009 9:05 PM
RS1 and speaker stands matty2767 Speakers 1 10-10-2009 7:35 PM
Old 10-10-2009, 9:31 PM   #1 (permalink)
Thanks: Gave 4, Got 1
What floor stand for MA RS1
Hey guys
I recently got RS1s and saw the GS10 floor stand at £293 and that is way out of my budget and was wondering if there is any better deals out there or cheaper alternatives for a carpetted floor. Budget depends on quality and limited to £100
Ayman is offline   Reply With Quote
Old 10-10-2009, 10:30 PM   #2 (permalink)
anpictum's Avatar
Thanks: Gave 12, Got 18
Re: What floor stand for MA RS1
I have RS1's mounted on Atacama Nexus stands filled with kiln dried sand. Very stable and firmly planted to the floor.
anpictum is offline   Reply With Quote
Old 11-10-2009, 11:00 AM   #3 (permalink)
Thanks anpictum
The RS1s are 185mm wide and 240mm depth and the atacama nexus is 145mm wide and 180mm depth. Isnt there a risk of it topling over.
My rears will need to be firmly planted because there will be a chance that the speaker wire or speaker will be brushed against. I should really find a better place for them, but im pushed for space and they will be brought in and out of there position when I need them, so they will not be tucked away safely when in use.
Old 12-10-2009, 1:28 PM   #4 (permalink)
Assured Advertiser
paul@big-av's Avatar
Thanks: Gave 0, Got 14
The atacama nexus speaker stands should be OK, there is an optional top plate which has 200mm depth, that would increase the stability, but even with the standard plate the stand will be OK, the most important thing to consider when buying a speaker stand is to make sure the base of the stand is larger than the base of the speaker which in this case it is, so you should be OK.
If you have any further queries do not hesitate to ask.
Paul
Big AV
01484 420088
www.big-av.co.uk TV Stands, HiFi Stands and AV FurnitureSuperstore. Price Match Promise.
email: sales@big-av.co.uk
Tel (furniture) - 01484 420088 / 01138151535
(electricals) - 01484 439030
paul@big-av is offline   Reply With Quote
floor, rs1, stand
