| Another false chimney, cabinet advice needed
Hi guys can you point me in the right direction for cabinets, I'm about to try and build a false chimney, and want my amplifier and bluray housed in cabinets and built into the chimney so that basically the "dials" would be flush with the wall, I also have a large centre speaker and also a set top box, I suppose what I am looking for is rectangular carcasses strong enough and deep enough to hold heavy av equipement, minimum measurements are W440cm H247 cm D479cm for amp and bluray and W800cm H350cm D350cm for centre speaker, thanks in advance for your help
