30-09-2009, 8:23 AM
#1 (permalink)
Thanks: Gave 2, Got 27
Trying and failing to find a big enough cabinet!
Hi all,
Is there such a thing as a cabinet, either a "vertical" style hi-fi rack, or a "flat" style av/tv rack with enough shelves to hold my receiver, NAD amp, bluray player, HD-DVD player, DVD player (not that vital tbh) V+ box, and have the top shelf free for squeezebox and maybe centre speaker?
If so, is it possible with a budget of around £200?
I've spent months searching high and low and can't find anything suitable  Any bright ideas?
Many thanks
Onkyo TX-SR705 Receiver, NAD C352 amp, Toshiba 42XV555DB HDTV, Toshiba HD-EP35 HD-DVD player, Samsung BDP1400 Bluray Player, Pioneer DV-575A DVD player, Virgin V+ Box, HTPC, Squeezebox3, Monitor Audio Bronze B2 fronts, Centre & Rear, Yamaha NSC120 centre rear, BK Monolith FF sub
30-09-2009, 9:28 AM
#2 (permalink)
Thanks: Gave 0, Got 36
Re: Trying and failing to find a big enough cabinet!
I've got one of these babies, that allows for as many shelves as you like:
Naim Fraim
Unfortunately, a £200 budget would only buy you half a shelf
My AV Stuff: Kuro 500-M plasma, Sony STR-DA5300 AV amp, Miller & Kreisel Speakers, PS3, Sony BDP-S350 Blu-Ray, Humax Foxsat-HD, Topfield PVR
30-09-2009, 2:20 PM
#3 (permalink)
Assured Advertiser
Thanks: Gave 0, Got 14
Reason: Removed text that breaks forum rule no. 7
30-09-2009, 2:53 PM
#4 (permalink)
Assured Advertiser
I forgot the Alphason Finewoods 1350 could be ideal for you also.
01-10-2009, 10:34 AM
#5 (permalink)
Location: Barton Under Needwood, Burton On Trent, United Kingdowm
Thanks: Gave 15, Got 30
Originally Posted by Howard0000
Hi all,
If so, is it possible with a budBget of around £200?
Many thanks
I would suggest one of the Sound Organisation stands in the price range you are looking at. Try ebay.
AV: Naim DVD5, HiLine, AV2, 250/145/200, 282/Hicap, n-System, Sony 710 & 860 DVD recorders, PS3, XBox360, Wii, Rega Radio.
Hifi : LP12 Lingo/Ekos/Dynavector Te Kaitora/Naim Prefix, Naim CDS, NAC52, 4 Naim 135s, HiCap, Naxo, Naim SBLs active, NAT01, Nakamichi CR7. AIWA DAT. Denon 1500 CD recorder
