Need a TV unit similar to Ikea BENNO
Old 04-07-2009, 12:07 AM   #1
beasty54's Avatar
10,858, Level: 25
Points: 10,858, Level: 25 Points: 10,858, Level: 25 Points: 10,858, Level: 25
Thanks: Gave 285, Got 357
Hi guys, i'm looking at getting a new tv in the upcoming months but need a unit for it to be attached to as i dont want it attached to the wall but i cant find one the correct size. The TV i'm looking at is a Pannasonic TX-P50G10 with a width of 1218mm. My speakers are 130mm wide each and i have a gap of 1620mm for the unit so ideally i need it to be 1600mm wide so it will JUST fit and be able to JUST accomodate the TV and speakers.
Ive seen a unit at ikea that i really like but its not wide enough so i just wondered if any of you guys knew of something similar thats 1600mm wide. Failing this i will need to have one built
IKEA | TV solutions | TV solutions for flatscreen TVs larger than 37" | BENNO | TV bench with panel
Last edited by inzaman; 04-07-2009 at 12:47 PM. Reason: Image breaks forum rule no. 9
