Premier AV HF0042
Old 23-06-2009, 12:21 PM   #1
1,986, Level: 10
Points: 1,986, Level: 10 Points: 1,986, Level: 10 Points: 1,986, Level: 10
Thanks: Gave 7, Got 11
Premier AV HF0042
Available from Premier AV HF0042 - Plasma & LCD Glass TV Stand Up to: Amazon.co.uk: Electronics & Photo
Does anyone have the full measurements - specifically along the back edge, which is shorter then the front? I've searched around and cannot even find the manufacturer name/website.
I want to place it in a corner - and it depends how far back I can push it into the said corner.
Old 30-12-2009, 2:20 PM   #2
5,362, Level: 17
Points: 5,362, Level: 17 Points: 5,362, Level: 17 Points: 5,362, Level: 17
Did you manage to find out the dimensions for this stand as I'm having the same issue. I'd also like to know the distance between shelves so see if my receiver will fit!
Many thanks.
Regards,
Ben
Old 19-01-2010, 9:51 PM   #3
1,986, Level: 10
Hi Ben,
[EDIT]Bugger, I got a very slightly different model - shape at the back is different. I would guess that the shelving hights are the same though[/EDIT]
Sorry for the very slow response, finally found a tape measure - will try and be concise as poss but let me know if there is any dimensions that I don't mention...
Front : 106cm
Back : 55cm
Depth : 46cm
Hight : 48cm
Bottom Shelf hight : ~19.5cm
Top Shelf hight : ~20cm
Hope that helps, lemme know if you need more. Measurements are fairly accurate, but give yourself a bit of a margin.
Old 28-01-2010, 4:26 PM   #4
5,362, Level: 17
Originally Posted by majortom34 View Post
Hi Ben,
Front : 106cm
Back : 55cm
Depth : 46cm
Hight : 48cm
Thanks very much. No problem about the late reply. I rarely get a chance to come back here myself but as I've just bought a 40w5500 I remembered to come back and check!
Thanks again.
Ben
