Originally Posted by M3M I looked at this yesterday Arnold and did a google search to find it with black satin legs but to no avail. Would it be possible for you to take a good quality photo of yours to see the colour? Try to get an accurate reproduction if you can without using a flash?
I'm wondering though if the power amp is going to fit on that bottom shelf. Hmmmm.  |
I'm sorry but ..
Horror of Horrors ! ... I don't have
any kind of digital camera leave alone one capable of taking a
good quality pic.
I'd be surprised if you can't specify Black in your order and that page does give the physical size of the beastie
But .. your best bet would be to phone Stand and Deliver and ask for their advice. I always found Stand and Deliver helpful when I phoned them for advice on load bearing of the Optimum stand when the on line catalog gave a maximum size for the TV that was plainly wrong. Mind you I did sweat a bit until it was confirmed that the table stand of my 608D would fit neatly between the top caps that fasten the table top of the stand in place and that confirmation came only when my TV dealers installers lowered the TV into place.
I did get an Optimum Catalog directly from Optimum and that was extremely useful. Let's see now where did I put the manufacturers web address? Ah, yes, there it is and still the same sort of range thought they do appeared to have freshened up their products names and titles here and there. I'll point you to the page that shows the range of legs in the modular system...
Optimum 2000 International - tv, hi-fi, audio, visual, stand, modular, units
Note ...
" The Optimum Modular stands come pre-configured with supporting rod lengths, but the beauty of this range is that the these length can be changed at the time of ordering at no extra cost - total flexibility. The rods are available in the following lengths
• 80mm 200mm 400mm
•120mm 230mm 500mm
•150mm 250mm 600mm
•170mm 320mm "
If you aren't in a tearing hurry you could get an Opimimum Catalog in good old fashioned paper and have it ready to hand when you phone Stand And Deliver.
I seem to recall that Stand and Deliver do one of those 'will not be beaten on price ' claims and so it may be worth your while to do a trawl of the web for rival suppliers after you have decided what you want.
Arnold.
