| My solution to centre speaker placement
This is an experiment guys, so please don't knock the craftsmanship or the quality of materials.
Anyway, to give you some background.... for years I've owned KEF awsome TDM23 THX speakers. They are huge and I needed to downsize.
But the problem with most ordinary speakers is that although smaller and slimmer the centre speaker is never upto the standards I'm used to.
Oddly enough, using a single ordinary speaker gets me closer to the TDM sound I'm used to, but brings another problem of speaker height... how on earth can you mount a tall, deep centre speaker in a central position? ... but I think I've done it.
I've settled on Mordaunt Short Mezzo speakers, and although the Mezzo 5 centre speaker is very good, a single Mezzo 2 does a better job (the Mezzo 5 I bought will be in the classifieds soon). So my solution is built around accomodating a Mezzo 2 as a centre speaker.
The solution was 3 fold:
1) to raise the TV behind the speaker on its own little 'platform'
2) to cut a hold in the shelf below for the centre speaker to 'peak' through'
3) build a shelf below that on which the speaker will rest, and which extends beyond the front of the cabinet to support the extra depth of the speaker.
Here it is.. what do you think?
