What stand for Onkyo 19cm high, Centre Speaker 17cm high, BD 13cm and 46inch LCD
Old 26-05-2009, 3:36 PM   #1
1,711, Level: 9
Points: 1,711, Level: 9 Points: 1,711, Level: 9 Points: 1,711, Level: 9
Thanks: Gave 1, Got 0
Just bought Sony KDL 46Z4500, Onkyo TX-SR876 AV receiver, Sony BDP S5000ES and the B&W 685 Theatre Speakers.
Getting a stand which can fit the B&W HTM62 centre speaker but then has enough shelf space for the AV Receiver, Blu Ray player and Sky HD box is proving a challenge...
The speaker is 17cm in height. Width of all are less than 44cm.
Depth of the stand is also an issue in that the amplifier is 46cm deep
Ideally I wanted the Amp, BD player and Sky box behind a glass front (to keep noise down) with the speaker on a shelf just above that with the TV on top...
Any thoughts on the best stand that doesnt cost the earth?
Old 04-06-2009, 1:16 PM   #2
SadR0bot's Avatar
3,762, Level: 14
Points: 3,762, Level: 14 Points: 3,762, Level: 14 Points: 3,762, Level: 14
Thanks: Gave 19, Got 26
Re: What stand for Onkyo 19cm high, Centre Speaker 17cm high, BD 13cm and 46inch LCD
Originally Posted by xcitable View Post
Good luck with that!
Ive been trying to find something similar for years now and still havent found anything which is suitable for me. I stumbled across VAMOS_DAN's purchase of the Alphason ACT1100 this week which looks perfect at first glance. In reality though its not quite there as Im not sure I can fit my amp on any of the shelves.
xcitable (11-06-2009)
Old 04-07-2009, 8:30 PM   #3
2,039, Level: 10
Points: 2,039, Level: 10 Points: 2,039, Level: 10 Points: 2,039, Level: 10
Thanks: Gave 3, Got 0
Hi there,
I am having the same problem! Did you manage to find a solution?
Old 06-07-2009, 2:37 PM   #4
6,702, Level: 19
Points: 6,702, Level: 19 Points: 6,702, Level: 19 Points: 6,702, Level: 19
Thanks: Gave 31, Got 29
Check these guys out..
Optimum 2000 International - tv, hi-fi, audio, visual, stand, modular, units
I've been on the verge of purchasing one of these myself for some time. Looks perfect as you can specify the height of each of the shelves, and they're 500mm deep which is just right for my Onkyo 876.
If you do a quick search, you'll find there a couple of people from here who have some pics of these too..
Old 07-07-2009, 6:10 PM   #5
6,978, Level: 19
Points: 6,978, Level: 19 Points: 6,978, Level: 19 Points: 6,978, Level: 19
Thanks: Gave 76, Got 42
i just ordered one of them!
Optimum 2000 International - Product Details
HOpefully will arrive 2moro, but as you say a quick search shows some on here who already have & with pics!
Will try n come back n offer my opinion once I have up n ready
Old 08-07-2009, 8:24 AM   #6
6,702, Level: 19
Cool, i'd appreciate that..
Any pics would be appreciated too as each one is bound to be slightly different (as they're so customisable..)
Old 10-07-2009, 8:34 PM   #7
6,978, Level: 19
Well cant complain bout it being or looking lightweight!
Dead easy to put together and very substantial! (10mm glass)
Mine like said was the AV400 (4 shelves) And came in at 70kg!!
Basically it came with 4 glass shelves, the legs as selected the top caps and plenty of fittings! (got spares!!)
Easy enough to put together, and with a little dusting it is up now n ready for action.
NO pics as yet but will try and take some over the weekend.
Want to know anything let me know
