Alphason ST600 90/2
Old 21-05-2009, 9:52 AM   #1
2,048, Level: 10
Points: 2,048, Level: 10 Points: 2,048, Level: 10 Points: 2,048, Level: 10
Thanks: Gave 3, Got 0
Alphason ST600 90/2
Im after a tV stand the alphason ST600 90/2 stood out looks really good Im going to put the new 40" sony w series on it as well as sky hd, ps3, wii & sony home cinema it will be in the corner of my room, will this do the job but also look amazing?? any opinions appreciated also any other ideas
Old 21-05-2009, 2:36 PM   #2
Assured Advertiser
m-formonline's Avatar
5,121, Level: 16
Points: 5,121, Level: 16 Points: 5,121, Level: 16 Points: 5,121, Level: 16
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 20, Got 299
Re: Alphason ST600 90/2
As another idea, if you're putting your Sony AV amp on the bottom/base shelf then this product would also do the trick;
M-Form - "PANDA" Floorstand for 32" to 52" TVs
Finished in black and white glass, it would also look fabulous with one of the white Sony Bravia EX1 screens!
Best Regards
Graham
www.m-formonline.co.uk UK Manufactured LCD and Plasma Wall Brackets.
info@m-formonline.co.uk see our blog or call 01159409169.
Old 21-05-2009, 3:11 PM   #3
2,048, Level: 10
are the top 2 shelves suitable for my ps3 & sky hd box, has to be adequate air flowing through especially around my ps3
Old 21-05-2009, 3:37 PM   #4
Assured Advertiser
5,121, Level: 16
Activity: 1.9%
Your SKY HD box would go on the lower shelf and the PS3 would go on the top shelf with 15mm to spare. With the PS3 on the top shelf there'd be no problem with ventilation as there'd be nothing covering it up.
See dimensions and details here;
M-Form
Hope this helps
Regards
Graham
Old 22-05-2009, 11:07 AM   #5
2,048, Level: 10
Do you have a shop where I can come and look at this stand?
Old 22-05-2009, 11:15 AM   #6
Assured Advertiser
5,121, Level: 16
Activity: 1.9%
We don't have a shop, we are factory direct. All I can do is assure you of the quality of the stand and if you weren't happy with it then it falls under our general returns policy.
Best Regards
Graham
Old 24-05-2009, 11:39 PM   #7
2,048, Level: 10
I still have no idea on which stand to get, the alphason st looks great but im limited for the amount of things I can add in the future, I like the look of the Ambri ABRD-1100 but not keen on a cabinet at the bottom, things like the ps3 need adequate ventilation has any got one of these with a lot of units how does it look and how does equipment run with cabinet closed, Thanks
Any other suggestions for a black corner glass stand would be recieved gratefully!!
Old 13-08-2009, 10:10 AM   #8
2,626, Level: 11
Points: 2,626, Level: 11 Points: 2,626, Level: 11 Points: 2,626, Level: 11
Thanks: Gave 62, Got 6
Hey,
which stand did you get in the end?
Old 14-08-2009, 12:08 PM   #9
2,048, Level: 10
I got the alphason sona avcr42, great after I got all the correct bits the right size & intact!! But an absolute nightmare to clean biggest dust magnet ever!! But has loads of room for my setup and looks great, hope this helps
