Go Back   AVForums.com > Audio Electronics > AV Amplifiers and Receivers
Today's price checkPowered by
Sony STR-DH800
NAD C315BEE
Yamaha RX-V465
Onkyo TX-SR507
Sony STR-DH800
NAD C315BEE
Yamaha RX-V465
Onkyo TX-SR507
Pioneer VSX-819H-K
NAD C326BEE
Yamaha RX-V3900
Pioneer VSX-919AH-K
Yamaha RX-V765
Yamaha RX-V565
 More...Prices updated November 24th at 7:30am and include delivery.
Which audio format for my iPod? Dorian Portable Music (MP3, iPod etc.) 46 11-09-2009 6:06 PM
Linksys Wireless Home Audio System ro53ben Streamers and Network Music Players 17 17-01-2009 11:49 AM
Sony 40W4500 - HDMI Input Problem when using Sony RDR-HXD970 DVD HDD Recorder JabezClegg LCD Televisions 7 11-01-2009 9:10 PM
PS3 HDMI Cable? Robbie J PS3 49 08-01-2009 11:32 PM
Laptop with hdmi? fango Laptops and Mini PCs 2 07-01-2009 10:48 AM
Old 07-01-2009, 10:57 AM   #1 (permalink)
HDMI and separate audio?
Does anyone know whether AV Receivers can handle passing through an HDMI video signal and use a separate audio source?
I have built a HTPC using the Asus M2NPV-VM, which I currently have hooked up to my TV via component, and the audio going to the amp.
As I'm upgrading my system, I want to switch to HDMI, so my plan was to get a DVI to HDMI converting cable, and hook that up to a new amp, which passes through to the TV, then I wanted to take a separate audio cable to the amp.
Is this possible with the current HDMI Receivers??
Paul
pjhepworth is offline   Reply With Quote
Old 07-01-2009, 11:40 AM   #2 (permalink)
Thanks: Gave 33, Got 7
Re: HDMI and separate audio?
I think they can, but I should no more in less than an hour. I have an A-V technician coming for some work and I'll ask him.
My Sky HD box in connected to the Onkyo 706 by HDMI plus an Optical digital cable. I have been told that the latter is required if I want to record Digital Audio signals from sky programmes.
Likewise, my DVD player is connected to the Onkyo by HDMI plus a coaxial digital cable. The latter might not be necessary, but it does not seem to be interfering in any way.
Of course, a high quality HDMI cable carries signals from the Onkyo to the TV in both cases.
Steppenwolf is offline   Reply With Quote
Old 07-01-2009, 12:26 PM   #3 (permalink)
Thanks: Gave 5, Got 0
Most decent AV amps allow you to assign a digital audio (optical/coax) input to a HDMI input. You may then also have an 'Audio Select' button that allows you to toggle between audio from HDMI or the other.
(speaking from experience of a Yamaha V3800 AV amp)
If the amp allows HDMI standby passthou, the audio will only be from that on the HDMI input. (ie Sky -> amp -> tv giving stereo audio)
HouseofMu is offline   Reply With Quote
Old 07-01-2009, 12:27 PM   #4 (permalink)
I think this is going to depend on the Receiver.
The one I was looking at getting can do it (Sony STR-DG820) using Digital Assign, and as this is in the lower end of the market, then I think better models should be able to handle this too.
Old 07-01-2009, 1:11 PM   #5 (permalink)
Thanks: Gave 147, Got 778
I was just going to post that the only one I know, that didn't was a STR-DG820, but this was recently fixed by a firmware update. So make sure you get one with the new firmware update.
dwhite is online now   Reply With Quote
Old 07-01-2009, 1:33 PM   #6 (permalink)
I am having the same issue with a DG720... How do I know which firmware is on it and which I need? Can you update it yourself?
thanx
joey3002 is offline   Reply With Quote
audio, hdmi, separate
