11-12-2008, 11:55 AM
#1 (permalink)
| | Moderator
Join Date: Mar 2006 Location: +56°28' 10.92"/-2°59' 21.48"
Thanks: Gave 635, Got 1,915 | STR-DG520, STR-DG720, STR-DG820 and STR-DG920 Discussion Thread *Part 2*
This thread is a continuation of the existing thread, which is now closed, and linked to here, in case anyone needs to check: STR-DG520, STR-DG720, STR-DG820 and STR-DG920 Discussion Thread
__________________ XBL / PSN Gamertag - RottenFoxBreath
- The views i express are my own, and in no way represent the views of AVForums or affiliates - |
11-12-2008, 5:44 PM
#2 (permalink)
| | Member
Thanks: Gave 3, Got 1 | Re: STR-DG520, STR-DG720, STR-DG820 and STR-DG920 Discussion Thread *Part 2*
hmmm why...?
Anyway! Is there a way of manually unassigning a digital assign without a full reset, as I have assigned and named numerous other inputs that i dont want to mess with...?
If there is no other option I guess I'll have to try that
11-12-2008, 6:51 PM
#3 (permalink)
| | Member
Thanks: Gave 95, Got 109 | Re: STR-DG520, STR-DG720, STR-DG820 and STR-DG920 Discussion Thread *Part 2*
I was thinking the same why? probs something to do with the update
Back on topic,
Make sure you have definetly got D.ASSIGN set to VD1 -> VD1. Select VD1 -> OPT and then scroll up and down to get to VD1 digital input.
I've just tested mine over optical and it works as it should. If you have VD1 assigned to VD2 it only gives me AUTO and ANALOG options not OPT.
Double check that the XBOX is outputting over optical look for the red light on your optical breakout box or end of your optical cable...
__________________ Consoles: PS3 60gb, Xbox 360 Elite, 360 HD DVD AV: Samsung Sync Master 226BW, Samsung DVDR125, Sony 32D3000, Sony STR-DG820, Onkyo 5.1 SKSHT518 XBL: shilzilla |
11-12-2008, 8:18 PM
#4 (permalink)
| | Member
Shil, I have sorted it, seems it was a faulty cable after all!
Really sorry to waste your time! Should never have doubted the sony...
11-12-2008, 10:26 PM
#5 (permalink)
| | Member
Thanks: Gave 95, Got 109 | Re: STR-DG520, STR-DG720, STR-DG820 and STR-DG920 Discussion Thread *Part 2* Quote:
Originally Posted by tikigod19 Shil, I have sorted it, seems it was a faulty cable after all!
Really sorry to waste your time! Should never have doubted the sony... | Ah, no problem matey....enjoy the system
12-12-2008, 6:05 PM
#6 (permalink)
| | Moderator
Thanks: Gave 635, Got 1,915 | Re: STR-DG520, STR-DG720, STR-DG820 and STR-DG920 Discussion Thread *Part 2* Quote:
Originally Posted by tikigod19 hmmm why...? | in the forum feedback/news forum, there is an announcement that all threads over 1000 posts, are to be closed,and new ones opened.
it doesnt cause a problem, a link to the old post is there, and nothing will be lost.
its no biggie, just a matter of housekeeping is all.
12-12-2008, 7:42 PM
#7 (permalink)
| | Member
Thanks: Gave 61, Got 42 | Re: STR-DG520, STR-DG720, STR-DG820 and STR-DG920 Discussion Thread *Part 2*
Well i purchased the 820 today from Richer Sounds. I got it home to find out that its still the old version despite them receiving new stock on Monday. Why on earth are Sony still sending un-updated stock out!!!  I thought anything bought now would bound to have the update!
Anyway, i thought i would ask if i will actually benefit from an updated version. I have sky HD (only the sports), will the sound through 5.1 be fantastically better than plain old stereo?, i guess that if i had the movies then it would be yes, but is it really that much better on sports and worth the hassle of returning, or waiting for new stock?
12-12-2008, 9:17 PM
#8 (permalink)
| | Member
Thanks: Gave 1, Got 6 | Re: STR-DG520, STR-DG720, STR-DG820 and STR-DG920 Discussion Thread *Part 2* Quote:
Originally Posted by Barthez Well i purchased the 820 today from Richer Sounds. I got it home to find out that its still the old version despite them receiving new stock on Monday. Why on earth are Sony still sending un-updated stock out!!!  I thought anything bought now would bound to have the update!
Anyway, i thought i would ask if i will actually benefit from an updated version. I have sky HD (only the sports), will the sound through 5.1 be fantastically better than plain old stereo?, i guess that if i had the movies then it would be yes, but is it really that much better on sports and worth the hassle of returning, or waiting for new stock? | Sony are not sending un-updated stock out but some shops are still selling them as they have still got them in stock.
12-12-2008, 9:21 PM
#9 (permalink)
| | Member
Thanks: Gave 23, Got 44 | Re: STR-DG520, STR-DG720, STR-DG820 and STR-DG920 Discussion Thread *Part 2*
The more I hear abour Richer Sounds, the less I want to buy from them.
They used to have a good rep didn't they?
__________________ :- Samsung LE40-A656 -:- Sony BDP-S350 -:- Samsung Sky HD -:- Yamaha AX763 -:- Kef KHT 2005.3 -:- Nintendo Wii -:- Toshiba Equium -:- (coming soon) Squeezebox Classic -: |
12-12-2008, 11:03 PM
#10 (permalink)
| | Member
Thanks: Gave 61, Got 42 | Re: STR-DG520, STR-DG720, STR-DG820 and STR-DG920 Discussion Thread *Part 2* Quote:
Originally Posted by scotty 1972 Sony are not sending un-updated stock out but some shops are still selling them as they have still got them in stock. | They must be as Richer Sounds only got the delivery on monday as i had been waiting for them to get some more in.
13-12-2008, 10:28 AM
#11 (permalink)
| | Member
how would i know if my unit is the newer model? Does it only effect Sky HD as I dont have that yet, however I seem to get 5.1 from sky + via optical
13-12-2008, 4:38 PM
#12 (permalink)
| | Member
Thanks: Gave 4, Got 21 | Re: STR-DG520, STR-DG720, STR-DG820 and STR-DG920 Discussion Thread *Part 2* Quote:
Originally Posted by Barthez They must be as Richer Sounds only got the delivery on monday as i had been waiting for them to get some more in. | This could have been sitting at the Richer Sounds warehouse for the past 6 months. I bought one today, what is the best way to check if it is updated? The sales person said it should be but I didn't get to check it.
Afterall, I don't have Sky HD yet so not a massive issue for me.
13-12-2008, 7:49 PM
#13 (permalink)
| | Member
Thanks: Gave 17, Got 9 | Re: STR-DG520, STR-DG720, STR-DG820 and STR-DG920 Discussion Thread *Part 2*
I plan on buying my STR-DG820 from richer sounds but plan on keeping the Sky HD plugged into the telly and run a optical cable into the amp and plug my ps3 into the amp then onto the TV.
Should i worry about recieiving a non fixed version. Should i just plug HD and ps3 into the amp.
Also im hearing complaints that with the STR-DG820 there is a hum buzz from speakers where on quite dialogue scenes- can anyone confirm any noticable huzz buzz from any speakers or even the unit.
Panasonic 46PZ85, PS3 Slim(320GB) ,Panasonic BD35, Samsung Sky HD( 1TB WD HDD Upgrade), Sony 2400ES Amp , Jamo A102 5.1 speakers, Sony VCR and a Alphason AD3/105-PB TV stand
13-12-2008, 8:49 PM
#14 (permalink)
| | Member
Thanks: Gave 80, Got 35 | Re: STR-DG520, STR-DG720, STR-DG820 and STR-DG920 Discussion Thread *Part 2*
I'm looking at getting the 820 for myself for Christmas
Just wondering if anyone could shed some light on the whole XM satellite Radio???
Is it only on American models? I thought it was an American service?
Any help would be appreciated.
13-12-2008, 11:40 PM
#15 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Re: STR-DG520, STR-DG720, STR-DG820 and STR-DG920 Discussion Thread *Part 2*
Hey,
I have a STRDG720 hooked up to a ps3 and a Samsung LCD using hdmi through the receiver.
What should I have the audio settings on the PS3 set too under audio output settings? PS3™ | Audio Output Settings
Do I need to check all the Linear PCM Channels such as 5.1 ch 48khz, 7.1 ch 48hz and so on...
Or can I just leave the two 2 chn (44.1 and 48) linear pcm channels checked, and the Dobly Digital 5.1ch and DTS 5.1 ch checked and still get all the new codecs played by the ps3 (TrueHD,etc...) and sent through the receiver when its sets to A.F.D auto?
The reason im asking it because when all the boxes are checked I'm unable to pick any other surround settings, when I hit Afd auto on the remote I get the message on the receiver display saying "NOT USED" and grayed out. I use my ps3 as a media center and like to have music on multispeaker and some divx and dvd movies on other surroud settings. With all the boxes checked I'm unable to change anything as noted.
Thanks for any help
And if I can't change it will the STRDG820 do what I want since in can decode the newer codecs itself?
