Yamaha RX-V671 & 4th Gen iPod Classic
Old 17-07-2012, 10:50 PM   #1
Hi Guys,
Is anyone able to use the above combination via the front usb/pod connection?
I know the pod is a relic but serves me well however using only the usb lead as that's all I have it charges but is not recognised.
My wifes nano is fine and works perfectly.
OM says the classic is supported on the cable but not which Generations?
Thanks for any info
p.s I haven't tried setting the pod to disk use to see if that makes any difference yet.
Jez
