Originally Posted by Stok13 When listening to a CD has anyone noticed that the sound appears more biased towards the right-side speaker? Or is it just my set-up.......I've swapped my speakers around even swapped them for the rears but the sound stays the same. Its still a nice sound just a little unnatural i.e. the stereo image is off centre.......if anyone has any advice on how to correct it I'd appreciate it.
PS. My kit consists of Onkyo 609, Dali Zensor 5 5.1 (5s for L/R, Vokal Centre, 1s for surround, E-12F sub), Pioneer BDP-LX52.
Cheers,
Greg |
I got my 609 when it launched but I do recall having this issue and it was due to Audyssey setup.
Have a look at what the speakers levels have been set at by Audyssey, you may find that they are different for left and right channels. If you set these the same (I always check it with a sound meter) it should balance.
Without teaching you to suck eggs though, don't forget that the dB rating is relative to THX reference, owners get worried that Audyssey has set speakers at say -6DB.
I use a cheap RS sound meter but there are free apps for iphone and Android. The accuracy doesn't matter here as Audyssey sets the levels, it is the gain relative to each speaker. Does just level them up.
Remember subs don't work properly with sound level meters and thats a whole new subject!
Hope this helps, it did for me and I haven't intended it to come with the proverbial egg!
Andy
