Originally Posted by Boom04 Hi Guys,
Reaching out in the hope that someone might have done this
I was thinking whether it is possible to re-program the sky remote so that rather than controlling the TV, it had some basic control over the v671, notably rather than controlling the actual TV volume, the sky remote controlled the 671's volume. Losing the sky remote functionality over the TV is not a problem as this is now covered by the v671 remote.
Has anyone done this? I can't seem to find any codes which might work?
Thanks |
Try this...
The Sky remote can be programmed to control some your amplifier's fucntions, particularly volume, mute and on/off. The code for the 671 is either 0204 or 1304 However it needs to be either a rev 8 or rev 9 remote. theres a label under the battery cover which will tell you.
Programming the SKY remote to operate the amplifier
1. Turn on the AV amplifier you wish to operate, press the TV button on the Sky Plus or Sky HD remote control.
2. Press and hold down the Select and 0 (zero) buttons on the Sky Plus or Sky HD remote control until the LED (Light Emitting Diode) blinks twice.
3. Input the 4 digit number into the Sky Plus or Sky HD remote control using the code from the list below. The LED should flash twice to confirm that the code was entered successfully.
4. Use the Left navigation button on the Sky Plus or Sky HD remote control to try and switch the AV Amplifier into standby. If the standby button works then the other AV Amplifier functions should also work and the correct code has been selected.
If all functions do not work correctly then repeat steps 1 - 3 as you would with the TV Codes. Work through all the 4 digit numbers for your amplifiers manufacturer, as listed below, until you find the code which supports all or as many of the AV Amplifier functions as possible.
Once it is set up you should be able to use the Sky remote as follows:
Left arrow: turns the amp on and off
Stop button: source selection
And assuming you've set up the remote for your TV -
up/down arrows: control the TV volume
right arrow: TV mute
