Originally Posted by Riverbank Got into advanced settings, got update-network up. Then the manual says to press info but nothing is happening. Think I have the 1.18 firmware |
Firmware update procedure
from the “ADVANCED SETUP” menu:
Press STRAIGHT repeatedly to select “USB” or “NETWORK” and press INFO to start firmware update.
Choices
USB Update the firmware using a USB memory device.
NETWORK Update the firmware via the network.
• If this unit detects a newer firmware over the network, the corresponding message will be displayed after ON SCREEN is pressed. In this case, you can also update the firmware of this unit by following the procedure in “Updating the firmware of this unit” (p.106).
If nothing happens then your firmware is up to date.
According to Yamaha, Version 1.18 is the most current version.
