Yamaha RX-A1010, RX-A2010 and RX-A3010 **Owners Thread**
Thread Closed
Old 16-06-2012, 8:40 PM   #301
Eminent Member
Thanks: Gave 131, Got 3,802
Originally Posted by tommo33 View Post
Hi guys recently bought brand new Monitor Audio RX6, RXC and RX1 to go with my Yam1010.
The RX1 on one speaker has scuffs to the white paint on the bass golf ball cone about 12 o'clock
position above the pointed dome in the middle. Although possibly only cosmetic I'm concerned
longer term this could have detrimental effect on the cone once it is out of warranty.
The fact it is new it should be perfect in my opinion and I'm not happy.
Am I being too fussy or am I being reasonable to expect a replacement?
Do you guys think I should take it back to the shop and get it replaced?
Return the item. The retailer should replace it and Monitor Audio are pretty good in terms of their customer care in regards to such matters. AS long as you've not caused the damage then you are perfectly entitled to a replacement.
Old 16-06-2012, 8:42 PM   #302
Thanks for the reply.
Old 17-06-2012, 12:59 PM   #303
Originally Posted by jhayman View Post
Congrats on you're purchase the 2010 is a Great a/v receiver .
I Los have an Android phone and an iPhone Yamaha has apps for both phones just go to you're android store and download it for free.
It's an awesome app I use it all the time.
Cn I ask why the scene buttons are useless for you?
I find them one of the best features on my unit..
I have the app and it works fine. My Equipment: Cabletuner(sagem) on hdmi1, Mediaplayer(eva9100) on Hdmi2, BR(BD-570) on Hdmi3, Satellitetuner on av6 and tv only output (lg 60inch plasma) and Network with Nas.
Scene1 gives Cabletuner(don't no why) scene2,3 does nothing. 4=radio.
Well how can I configure this, now i use 5,7 for mediaplayer and dvd player.
Napster is dead can it be removed?
I use also a 4toall remotecontrol with powerswitch very handy everything on/off
Lots of problems
Old 17-06-2012, 1:18 PM   #304
Eminent Member
Lots of problems
If you want to reconfigure the default preconfigured scenes to something else, simply hold down the scene button you want to reconfigure while watching/using the amp as you'd want that scene to be defined. Hold the button down until the display indicates the new settings have been saved to that scene.
Old 17-06-2012, 3:15 PM   #305
jhayman's Avatar
Thanks: Gave 0, Got 4
Lots of problems
Like dante01 said to use the scene buttons the way you want simply turn on your equipment , say you want to watch TV using scene 1 , set up your stuff like your watching tv then just hold down scene 1 for a few seconds and it will tell you it's now configured.
Then say you turn off all your equipment simply press scene 1 and it will turn on everything just like you programmed it for watching TV.
The manual is very clear with scene buttons and how to use them.
Old 18-06-2012, 10:16 AM   #306
Is there an advanced reset option on a RX-A2010?
The receiver switched 3 times off, because no speaker were installed...
Now there is no function anymore, only standby, like the manual says.
SoftReset (press ON for 10sec) is possible, but AVR stays in standby.
Advanced setup Menue (ON and straight) is not working...
Old 18-06-2012, 7:56 PM   #307
Got it from Yamaha repair Center:
Press "Info" and "Tone/Balance" the same time and then switch on.
An Info appears like "no protect" or "i-protect" for 2 seconds.
Then there is a Menue for scrolling with zone 1/2.
My case: change preset INH to RSRV by using zone 3/4 and switch off.
Switch on, works perfect.
Eitzel (19-06-2012)
Old 20-06-2012, 4:46 PM   #308
Thanks: Gave 2, Got 3
Just to let you all know ive seen the 3010 at severnoaks for sale at £1299 bargain of the year.
Old 21-06-2012, 3:25 AM   #309
RX-A3010 keeps cutting
Hi - I am new to this forum, and have purchased an RX-A3010 ... after several minutes it keeps cutting out ... please help me.
Norman
Old 21-06-2012, 3:37 AM   #310
jhayman's Avatar
Norman
Thats a very vague description Norman..
How about a little more info, like where it's connected to and what's plugged into it and so on..
Old 21-06-2012, 4:38 AM   #311
RX-A3010 is cutting out
Thanks for the reply ... to be more specific it cuts out when the volume is 'somewhat' high. I must be clear that it is not nearly at max volume. When I turn the volume down this problem does go away.
This problem exists when playing both CD's and iPod. There is a 9 channel stereo setting if this helps.
When turning the unit back on after it cuts out the error message "check speaker wires' does show ... but the message immediately goes away and the unit begins to work normally.
Is there anything else I can clarify to help with this troubleshooting problem.
THanks,
Old 21-06-2012, 7:55 AM   #312
Chord Freak's Avatar
Thanks: Gave 13, Got 5
THanks,
I take it you've double-checked all the wiring and have allowed ample space around the reciever for air circulation? It sounds like it may be tripping the protection circuit due to overheating, have you felt how hot it is once it cuts out?
Old 21-06-2012, 9:15 AM   #313
Assured Advertiser
Thanks: Gave 44, Got 318
we have them as well :-
http://www.avforums.com/forums/home-...mav-co-uk.html
Old 21-06-2012, 12:50 PM   #314
heat buildup could be a probem
The unit is in a cabinet ... I know not advisable ... but does have doors open when running and venting ... but no fan as of yet. I am going to watch the heat when it does cut out ... I am assuming that as volume increases the amps build more heat ... this may explain it. I don't believ the problem is wiring as the unit does not cut out at lower volumes. So thanks, you have put me onto the 'heat' watch.
Old 22-06-2012, 11:09 AM   #315
Yamaha RX-A3010 streaming of Apple Lossless (ALAC)
I have a RX-A3010 and would like to stream music from my MacBook Pro and possibly a Mac Mini. Most of my music is in Apple Lossless (ALAC) format, some in AAC and very little in MP3.
Apple products are not DLNA compliant, so I have downloaded two front-end DLNA server softwares, (TVMobili & Elgato EyeConnect) which both work very well with the AAC/MP3 files, but not ALAC - EyeConnect just says cannot play file and TVMobili has a go at transcoding to WAV I think, but I get white noice being played, not music.
Does anyone know of any software, free or paid for, that will run on MAC OSX and successfully transcode ALAC files to another format that the Yamaha amp will play?
Any help would be appreciated.
Old 24-06-2012, 10:10 PM   #316
Thanks: Gave 52, Got 74
Volume lines diappeared - OSD - black bar only :(
Hi everyone,
I have a 2 month old RX-A 3010. For some reason since yesterday I only get the black bar displaying on the TV - the actual volume level number and the vertical lines are not showing I have established that it doesn't seem to matter which AV input is selected - I have 2 satellite receivers, Xbox360 and PS3 all connected via HDMI and HDMi 1 out to the TV. All fine until yesterday.
Ideas anyone?
Thanks,
Simon
Old 24-06-2012, 10:30 PM   #317
jhayman's Avatar
Originally Posted by madhouse
Hi everyone,
Ideas anyone?
Thanks,
Simon
Sorry never experienced that before, have you tried a factory reset?
After that if it still happens I think you have a defective unit.
The Aventage warranty is awesome, 4Years
madhouse (24-06-2012)
Old 24-06-2012, 10:32 PM   #318
No - not tried yet as was hoping I had pushed a button or something by mistake
But looks like I will have to take that route
Thanks,
Simon
Old 25-06-2012, 8:30 PM   #319
factory reset did the trick. I also restored the system backup I had made earlier - still all as usual
Cheers,
Simon
Old 25-06-2012, 8:54 PM   #320
jhayman's Avatar
Cheers,
Simon
Glad it worked..
Old 25-06-2012, 9:47 PM   #321
Meridius's Avatar
Thanks: Gave 73, Got 99
Do these 3010 get hotter or just the same as a Yamaha 3900 as I own one one these and it's been placed in a alphason stand cabinet and it's been fine.
I was hoping the 3010 was going to be much cooler at running and produce less heat than the 3900.
Old 27-06-2012, 8:18 PM   #322
Meridius's Avatar
Anyone ?
Old 29-06-2012, 12:37 AM   #323
Thanks: Gave 31, Got 23
Hi guys,can anyone recomend a cheap smart phone type thingy to control my A1010,all the phne would be required for is this realy.
cheers
graham
Old 29-06-2012, 2:12 PM   #324
Thanks: Gave 81, Got 156
Any IOS or Android device will do the trick, so you just want the cheapest. If you want to stream directly from the phone then you'll need some storage on board.
Look on Ebay for any cheap Samsung/HTC for Android or Iphone/Pod Touch.
Just as a guide there are loads of Galaxy Ace's on there for just over £100, I'm sure there are cheaper solutions as well. Incidentally the Yamaha AV Controller App is very good so worth getting something to use it.
Old 29-06-2012, 3:49 PM   #325
Thanks: Gave 436, Got 214
Just got one of these..
http://www.amazon.co.uk/Sumvision-Cy...cp_computers_0
Old 29-06-2012, 6:10 PM   #326
cool...like it lisag,thanks for the info guys,i know what i need now
Old 03-07-2012, 6:48 PM   #327
A2010 Hai again I just don't understand the filosophy of the Yamaha designers. I have a simple problem, I connect a media[player to hdmi6. Now I want to listen to the music on the mediaplayer. I can never find with buttons to use to hear the music.
Before I had a AV-rx767 where you only have to select hdmi6 on the inputsourcebutton.
My thanks are great!
Old 15-07-2012, 12:29 PM   #328
Jonwsm's Avatar
Thanks: Gave 0, Got 3
First post here, so please be gentle with me, lol. The 1010 doesn't have AirPlay, but is there another way I can stream to it via wifi ( apart from buying AirPlay separately) from an iPhone? At the moment I have an Arcam avr250, an I'm hoping the yammy can match the sound.
Old 15-07-2012, 12:46 PM   #329
You can use the av controller app to stream directly from iPhone/ ipad
Old 15-07-2012, 12:53 PM   #330
Jonwsm's Avatar
So I don't need AirPlay then? Are you saying that the music on the iPod magically plays through the amp? Does this work with the spotify app do you know?
Thread Closed
