I know I'm a newbie here but I really need help guys.
I've just bought a home cinema set (playstation 3, panasonic 42txv20, Monitor Audio RX6 AV12 5.1, Pioneer LX83 and, soon to come, beamax screen and jvc hd950 projector).
1 - It's the first time I have a home cinema worthy of that name so I need some help configuring it. Well.
In the speaker system settings of the lx83, i don't know what option to choose. There is this "normal" preset but it looks like it has 9.1 speakers! (2 back surround, 2 front height). then there's a zone 2, which looks like a 5.1 set with an extra stereo in another room. Then there's the bi-amp set, which also looks 5.1 but the front speakers are different, I don't bi-amp them, so I guess it's not this either...
Any help?
2 - In the subwoofer, i put the lfe in the out position, and in the amp, set the xover to 80 hz. is this good?
3 - What presets do you use for bluerays and music? for bluerays I usually just put the "direct stream" option (in the screen it shows dts-hd mst). But I don't know if I should do any more stuff (it has so many things, thx movies, optimum surround, auto surround, etc.). Am I doing it fine? For music I usually put it in direct stream too (while it is in stereo mode). Any recommendation here?
4 - any more settings i should "tweak" ? there is xwave, pqls, control, full phase, etc etc
That's all, I would very much appreciate any light anyone can shed on this. Oh and by the way, I still haven't mounted my surround speakers on the wall (will do it this weekend), so they are currently on the sides (and a bit to the back) of the couch, on two small tables, so they are below ear level. I don't feel the surround effect a lot. I guess it's because they're not properly placed yet. I've just tried iron man 2 and xmen: wolverine
Thanks!
