Pioneer SC-LX83 owners thread
Old 12-04-2012, 4:07 PM   #931
Hi all
I’m looking at getting one of these second hand to replace my Denon 1910,
It will be used with Kef Q500 fronts Kef Q200 centre and Kef T301 rears, and mini impact sub and a PS3 as blu ray player.
Is anyone using the Kef Q speakers with this amp? and how much better will it be over the Denon
Old 13-05-2012, 9:01 AM   #932
Thanks: Gave 2, Got 7
hi please let me know pioneer lx 83 can drive speakers 4ohm thanks
Old 15-05-2012, 10:08 AM   #933
Audio on Pre Out
Hi all,
could you please help me out. I have the LX-83 pre outed to my stereo amp for music on front left and right. I have just added speaker B in the adjacent room. I am really struggling with the following;
When i do the MCACC with the stereo amp set to the aux for pre out of front L/R audio from the LX i keep getting error from the L/R channels ?
Since adding the speaker B i can only get audio out of the main room front channels if i have it set to speaker B or both, so this then means sound blaring out from the adjacent room. If i set it to speaker A no audio ?
I know there is a zone 2 option but i have no amp to drive 2 small speakers.
Is there a way around this ?, the music sound using my dedicated stereo amp is far better than the LX83, i do have the following leads pre laid and available from the adjacent room phono, optical & obviously the HD cable connected to HD 2 out on the LX.
Pioneer have said that the amp can only recognise one format speaker B or a pre out to another amp not both. I know some one here will be able to cack this !!.
Many thanks for your help.
Telluride.
Old 29-05-2012, 1:44 PM   #934
jouster's Avatar
Thanks: Gave 19, Got 98
Got the dreaded flashing iPod light online at the weekend which means it is on r again with the local Pioneer Service centre. Very glad to find out this amp has a 2 year warranty.
Will however be writing a long snotty email to Pioneer UK afterwards stating if it goes up the swanny again (even out of warranty) that I'll be wanting a new amp.
Shocking quality from a supposedly superior brand
Old 13-06-2012, 11:04 AM   #935
humming developed from HDMI inputs
I recently bought a new blu ray player and swapped around the hdmi leads in the back
now for some reason I have a background hum from the hdmi inputs
I have disconnected the player and just run one item through and the hum is still there
Can anyone give advice on the problem?
Old 08-07-2012, 1:53 PM   #936
Thanks: Gave 7, Got 8
Hello,
I have recently been suffering from sound drop outs when watching Sky tv. It happens only very momentarily and is a very recent problem. I thought it was a Sky box problem and posted on the Sky HD forum, but no conclusions were reached and seemed to cause more arguments then anything else. I am beginning to think its the connection to the amp that's the problem and not Sky hardware.
I watched a bluray yesterday and it didn't happen then.
When playing back a Sky programme when a drop out has occurred, it does not happen again.
I am trying a process of elimination here so I have ordered a new optical cable from Sky to amp.
Any ideas would be appreciated.
Thanks.
Old 08-07-2012, 2:35 PM   #937
Hi can anyone help me please! My 83 seems to only want to playback sound in PCM when I play a ps3 game! Does anyone know how I can get Dolby sound when playing a game? Thanks
Old 08-07-2012, 2:38 PM   #938
DodgeTheViper's Avatar
Location: Searching for . . The best that I can get :-)
Thanks: Gave 339, Got 670
It's more than likely an audio setting in your PS3. Can it be set to bitstream in the settings ?
At the moment your PS3 is decoding the audio, when you want your Receiver to do it.
Old 08-07-2012, 3:19 PM   #939
Thanks viper,
Ive just checked the ps3 is set to bitstream... im getting so frustrated with the 83 now. I got it a few weeks ago and still cant work out why it plays audio in pcm when i play a game. when i watch a movie on the ps3 it plays in dolby sound so im struggling to understand. I replaced my denon with the pioneer and didnt change any settings on the ps3 but for some reason i cant get the 83 to play surround with a game, any more ideas anyone?
Old 08-07-2012, 3:32 PM   #940
Try toggling through the audio button on the receiver itself. Trying to remember were that is, I think it's behind the flap on the left
Or check the audio sig button behind the slide down flap on the remote
Old 08-07-2012, 3:35 PM   #941
cheers viper, will keep trying
Old 08-07-2012, 3:48 PM   #942
Viper.... you mentioned earlier about getting the amp to do the decoding. How do i do this? so i guess you are saying that for dvd blu-ray music etc the amp can do the source decoding which must produce better sound quality than the source... within reason. Is that right?
Old 08-07-2012, 3:50 PM   #943
Set your source player to bitstream, and the 83 will decode the audio. Behind the flap on the receiver is there a button that says 'auto surround'. ?
Old 22-07-2012, 6:16 PM   #944
Johnson23's Avatar
Hi, wonder if anyone can help please? My LX-83 cuts out when I do an mcacc set up. Whenever it gets to the front right speaker it shuts down and the on off switch flashes. I"ve checked for loose speaker wires, but they are ok. Guess it's got to go and visit Mr Pioneer. Does anyone have an idea what the approximate cost will be, just so I can judge if the quote is realistic. It cut out recently during a movie as well. Box didn't feel hot. Hadn't been on long.
I've also had problems connecting an amp to the f r pre-outs. Connected f r spkrs to the integrated amp and the interconnects to the front pre-outs. Just got buzzing and now I think it has damaged my exposure integrated amp. Thanks in advance.
Old 22-07-2012, 9:40 PM   #945
Try swapping your fronts. Connect the right speaker to the left channel and the left to the right. See if the Amp goes into safe mode now testing the left channel
I know that sounds stupid but its to confirm if the its the Amp at fault or the wire/speaker.
Let us know how you get on.
Old 23-07-2012, 8:07 AM   #946
Johnson23's Avatar
Thanks Napsterr, hadn't thought it could be the speaker, I'll give it a try over next couple of days and let you know.
Old 23-07-2012, 9:00 AM   #947
Hi did any of you guys face a problem with the pioneer sclx83 stop work and every time I try to turn it on it die after
3 seconds. The blue light of the iPod keep flashing but the amp is dead try to reset it with no help.
Would love to hear any ideas.
Old 23-07-2012, 3:45 PM   #948
jouster's Avatar
Yes. Happened to me a month ago. Turned put to be capacitors on the power supply has gone pop
So needed a trip to service centre. Luckily mine was under warranty.
Best of luck getting it sorted.
Old 23-07-2012, 6:46 PM   #949
pioneer SC-LX 83
hi Juster, thanks for your reply. i really think its strange that on such a level of Pioneer this things should not happen . i have own Yamaha & DENON for years and years never ever happen to me such a serious
malfunction . Maybe i should return to Denon or Yamaha.
Old 23-07-2012, 8:06 PM   #950
Johnson23's Avatar
Hi re my problem earlier in thread of lx83 cutting out on mcacc set up, I swapped over front left to right as suggested and tried it and it still cut out. Disconnected high level connection lead to my xxls400 sub and it went through mcacc test with no problems. Please can I ask if it is ok to connect a sub's high level to the lx83? I'm fairly sure I asked the man at bk elec when I ordered the sub? Thanks again for your help.
Old 22-08-2012, 2:09 PM   #951
Adjusting zone2 sound...
Hi! Is it possible to adjust zone2 treble and bass? And is there anyway to get wifi to 83? Thx.
Old 04-09-2012, 3:46 PM   #952
ninehours's Avatar
Thanks: Gave 132, Got 100
My 83 keeps shutting itself off when i try to turn it on, there is a flashing blue light on the front after it turns off its the iPod/Iphone light (Don't own either) anyone got any ideas?
Old 04-09-2012, 3:49 PM   #953
jouster's Avatar
I've mentioned on this thread before its a service centre job.
On mine it happened to be be two resistors had popped on the power supply so they needed replacing.
Are you inside the two year warranty?
ninehours (04-09-2012)
Old 04-09-2012, 5:33 PM   #954
ninehours's Avatar
Thanks jouster, i am not sure will have to dig out my paperwork
Old 04-09-2012, 5:41 PM   #955
jouster's Avatar
To be honest this is happening a lot so write a snotty email to pioneer customer services and even if our d warranty they might sort it. Shouldn't happening on an amp of this calibre
Old 05-09-2012, 6:22 PM   #956
ninehours's Avatar
Found receipt and am still within the 2 year warranty (expires November), contacted Sevenoaks today and am taking it to them Saturday. Hopefully it will be a quick and simple repair.
Old 05-09-2012, 6:38 PM   #957
jouster's Avatar
Think mine was done inside 10 days. Great news on warranty
Old 11-09-2012, 3:07 PM   #958
ninehours's Avatar
Do you know did they replace the parts with upgraded components or simply do a strait part for part replacement, if they replace the parts for the exact same components wont they just go wrong again and this time it will be out of warranty
Old 21-09-2012, 2:00 PM   #959
Movieman's Avatar
Thanks: Gave 18, Got 14
well mines gone as well, blue flashing ipod light. luckily only had it 11 month so still inside warranty dates. Taking back to shop on monday, I very surprised to find so many owners having this problem, with such a reputable brand, had yamaha and Lexicon most of my AV life and never had one minutes problem.
Old 22-09-2012, 7:29 AM   #960
Guys,
Please check troubleshooting section of the operating instructions (page118).
It says: "when receiver switches off and iPod lightflashes -> check speaker wiring for loose strands of wire touching rearpanel or other set of wires".
Additionally you can set 'D.SAFETY' to either 1 or 2 (page 119).
Speaker impedance must be within 6...16 Ohm. If you try to connect4 Ohm speakers then you will see 'iPod light'...
