Can we make it the x67 owners thread? I have a 767 i'llmbe picking up on Monday and I expect settings etc are similar across the range?
Hi I am new to these forums but would really like some advice. I have just read the what hifi october issue amp test and really would like to purchase the yamaha rx-v667. The question I have is will it pair well with Kef 2005.3's , I already own the speakers. I used to have the onkyo 607 but want to make the upgrade to 3D. Any advice would be appreciated before I spend my hard earned cash.
On the HDMI inputs at the rear, it has BD/DVD marked at the HDMI 1 input,
Why?
One would assume because that input corresponds to the source button marked as BD/DVD on the remote? By labelling the corresponding default inputs it makes life a lot easier when it comes to wiring the whole thing up
When setting up with the mic for our sofa, it seemed very quick, certainly <5 minutes. Result appears fine, when listening to SACD, and watching Sky HD movies sound stage seemed pretty good to me! Didn't do the multi-position option, went with the mic on a camera tripod positioned midway between the ears of the two people usually sitting on the sofa!Any tips for setting up? Does the auto mic setup take ages and/or get very loud? And is there a benefit to the multiple position calibration? We have a corner sofa so in theory some people could be fairly off to the right, but hardly ever, so is it necessary? Does it have value in improving the general sound stage?
cheers.
I thought I was being careful, marking up which speaker wires were which and which inputs etc from my old amp. Just about to hook up my 767 and realised I hadn't marked +/- on the speakers! Is there a simple way to work out which way round they go? I've had a look at the speaker end and there doesn't seem to be any markings on them to help
Hi, Could someone confirm for me that the standby passthrough is switchable between inputs when the amp is in standby. I seek the nirvana of 1 hdmi running to the TV, but don't want the amp on constantly, so if this works then that would be cool.
DC
As far as I know the it will pass through the last input you have used
So if you want to watch sky,
without the amp on make, sure sky was the input you had on before turning amp off
Is that clear peeps.. as I'm usless at explaining things.
Thinking about getting the RXV 667, does anyone know if the zone 2 output can be linked to a 5 way speaker switch to distribute around house?
