Anthem MRX Series Discussion Thread
Thread Closed
Old 10-02-2012, 7:37 PM   #301
Thanks: Gave 1,388, Got 185
Originally Posted by BobbyMac
Really impressed watching a DVD last night with the steering and clarity of the dialougue, less impressed with the paltry 6 input selection on the remote (might have to use my HDMI Switch)
However the proof of the pudding with ARC will be tonight when I compare the Anthem against my Audiolab M-DAC for 2 Channel duties
Dont forget the mrx digitizes all inputs, I asked on avs about dac's and was told not to bother!
Old 10-02-2012, 7:43 PM   #302
Thanks: Gave 128, Got 173
Depends if you subscribe to the premise that all DAC's sound the same
I'll be comparing digital coax vs digital toslink (simultaneous feed from a Squeezebox Touch) via a Beresford speaker switch
Should be interesting
Old 10-02-2012, 7:52 PM   #303
Cant wait!
Old 11-02-2012, 1:59 PM   #304
Andris L's Avatar
Thanks: Gave 1,843, Got 583
My MRX-300 goes on a wagon on Monday so I should get it on Tuesday/Wednesday!
Old 11-02-2012, 2:08 PM   #305
You won't be dissapointed
Old 11-02-2012, 11:30 PM   #306
DrGekko's Avatar
Thanks: Gave 392, Got 206
Chris & Dan @HCC
Hi Chaps,
Just wanted to thank you again for your recent superb service during the purchase of the JVC DLA-HD750 - just waiting to get it calibrated, should be next week.
Now in full swinging fever of "upgradetitis", I've been enthusiastically reading about the Canadian Anthem AV receivers.
I currently own a Yamaha RX-V1900 which is powering a 7 B&W CT700 series speakers and 2 Velodyne 12" subs.
Would you be able to comment on what sort of improvements I would expect from changing my amp to the entry level MRX300? Would this be a sideways shift or a genuinely signficant upgrade? Should I be considering the 500 or 700 perhaps?
(I've also emailed this message to you along with a request to offer a part-ex deal for my Yamaha.)
Old 13-02-2012, 11:19 AM   #307
Are there any Android or Apple Apps for the MRX series?
Old 14-02-2012, 12:14 PM   #308
Andris L's Avatar
It's here, it's here!
Old 14-02-2012, 3:28 PM   #309
Well? ARC'ed yet???????
Old 14-02-2012, 3:45 PM   #310
Andris L's Avatar
Just finished putting back all the kit in my rack. Will need to dust of my old PC and load software for ARC next however, I'm going out for a dinner at 18.00 so running out of time. Most likely will get it up once back later on tonight .
TopMeTom (15-02-2012)
Old 14-02-2012, 5:11 PM   #311
Thanks: Gave 47, Got 11
Please let us know how it goes, I think this could be the trigger for me!
Old 14-02-2012, 5:34 PM   #312
SteveRSF's Avatar
Thanks: Gave 1, Got 1
I really don't think there is a such a thing as "average price" when it comes to Anthem. It's seams that every retailer I looked at sells MRX-300 for £1100.
So, as the only amplification I would have would be the anthem,is it worth me spending more money for the 700 ?
Rest of my kit is below and room size is 5.5x6.0 m
Cheers Steve
Old 14-02-2012, 5:59 PM   #313
Conspicuous Member
Crustyloafer's Avatar
Thanks: Gave 214, Got 1,281
Cheers Steve
If you are going to be using the amplification onboard the Anthem then there is a definite step upon performance as you go through the range, particularly the MRX700 with the toroidal transformer.
Old 14-02-2012, 6:19 PM   #314
SteveRSF's Avatar
Yeah thought so ,do you think it would be far better than my old Yamaha a1 in your opinion crusty?
Old 14-02-2012, 6:25 PM   #315
Conspicuous Member
Tricky one, the bare bones amplification in your A1 is probably on a par with the MRX700, however the processing and more importantly the ARC room correction will put the Anthem several rungs up the performance scale.
A demonstration at whoever is your local dealer should seal the deal once you have heard it. Please also be aware that those not used to hearing a system with such a clean flat response might not warm to it initially but do give it a chance.
Cheers,
Chris.
Old 14-02-2012, 8:47 PM   #316
SteveRSF's Avatar
Thanks for the info chris ,need to get down for a demo methinks !
Old 14-02-2012, 9:35 PM   #317
DrGekko's Avatar
I'm suffering with the lament and obsession of potential upgrade time!!!!
Here are my thoughts/queries.....
1. Setting up The Anthem - I've read that it may take ages to set up using a laptop and really, should be done by an installer. What are people's opinions on this?
2. With my budget in mind, what would you choose between these.....
Anthem MRX 300 or 500 to replace my Yamaha RX-V1900
or
Keep the Yamaha, & purchase a decent 3 channel power amp (like Linn or Rotel) to power the front soundstage?
3. FInally - if someone offered me an Arcam 500 for £850 or Arcam 600 for £1600 - would these be clear choices above and beyond the Anthem 700, pound for pound?
Old 14-02-2012, 10:26 PM   #318
or
1) If you can connect a couple of USB cables, position a microphone stand in 5 positions and can install simple PC programs, it's a doddle to run ARC in Auto Mode, my 1st go took 30 mins (and that was double checking every step)
2) Get the MRX 300 and use the saved money towards a poweramp (but run the Anthem as a receiver, you may find out you don't need to beef up the amp section
3) Without having heard an Arcam 500 or 600, the general consensus is that the Anthem is better for Movies and the Arcam is better for Stereo Music in Direct Mode. However if you have a difficult room ARC pisses all over Arcam's EQ system.
The Arcam 600 is meant to be something very special for 2 channel and the Arcam 500 is meant to have 90% of thr 600's SQ
If you can try and demo both Anthem & Arcam Amps or if you can only take a blind punt on the Arcam, you wouldn't lose much on resale value if you decided you preferred the Anthem
DrGekko (14-02-2012)
Old 14-02-2012, 10:51 PM   #319
DrGekko's Avatar
Originally Posted by BobbyMac View Post
1)
Aaagghh!! Don't tempt me, I'm going over the edge!
I'm seriously considering this option - basically, I'm tired of simply replacing equipment over the years. I want to get a solid grounding and build up.
Eventually I'd love to be using power amps such as Anthem's A5 & A2 or Rotel 1575 for the various channels.
I really want to hear a substantial improvement now and then build up the entire system patiently thereafter - is there any point getting a quality 3 channel power amp now and using Yamaha as the processor and power amp for surrounds? And then saving up to get a quality processor next year?
Old 14-02-2012, 10:59 PM   #320
I had an Yamaha 3900 until late last year, the MRX 300 is a definite improvement in Sound Quality
Old 14-02-2012, 11:02 PM   #321
DrGekko's Avatar
In what way??? Do tell!
Also, can I connect both my subs to this?
Old 14-02-2012, 11:11 PM   #322
Andris L's Avatar
I didn't manage to finish my set-up tonight so will have to wait till morning. Missus is away with the kids tomorrow morning so I'll have some peace to play about with my new toy .
Old 14-02-2012, 11:12 PM   #323
Andris L's Avatar
As far as I can see there is only one output on MRX-300 (not sure about other two models) so you'd have to link your two subs together or use Y splitter.
Old 14-02-2012, 11:13 PM   #324
The Anthem has more clarity and music/dialogue is more defined, basically less muddy
Don't get me wrong the 3900 was good in it's own way (and was DSD direct with SACD), however the Anthem is a level up from the 3900 (and as the 3900 was a tier up from your 1900, I don't think you will be dissapointed
You can run two subs on the MRX 500 & 700, but you need to run ARC with one sub attached at a time according to the user manual
Old 15-02-2012, 7:32 AM   #325
richmagnus's Avatar
Thanks: Gave 403, Got 300
or
The Arcam 600 and 500 will be better for both stereo and multichannel music. That is if for the multi channel you have a great listening room that doesn't need EQ. If your listening room will benefit from EQ and most do the Anthem MRX 300 with a quality power amp would be the way to go IMO. The Arcams are fab but with very very basic EQ. I have the 500 and love it. If you wish to upgrade amps in the future only the 600 has pre outs not the 500.
If I ever changed my ARCAM I would get an Anthem.
Old 15-02-2012, 9:29 AM   #326
Thanks: Gave 95, Got 212
wow ! is it so ugly you are going to have to use it in the box ???
good choice though - I've been tempted myself
Old 15-02-2012, 11:34 AM   #327
Rock Danger's Avatar
Thanks: Gave 108, Got 450
I'm trading my AVR600 in favour of an MRX500 as a pre amp. And then probably add some giant power amp on the end, be it an Arcam P777 or some giant sunfire thing.
Old 15-02-2012, 11:47 AM   #328
Where u trading from? Out of interest? I may be downsizing of sorts on the speaker fronts so am interested in who tades kit in? It may mean me trading my 300/1575 in for just a 700?
Old 15-02-2012, 12:03 PM   #329
Thanks: Gave 28, Got 48
Rock danger - you will not be disappointed in your choice - Finally it seems the message that Anthem has a quality and compelling range of AVR's that does what it says on the tin and then adds the magic of ARC and god forbid works reliably is beginning to get through .
Is Anthem the new Arcam
Old 15-02-2012, 12:04 PM   #330
do you need teh extra features of the 500 over the 300 ? Just other than that the pre-amp stages are the same on all MRXs
I thought you were in love with the Arcam ?
Thread Closed
