So I've 99% decided on buying the LG 50PK590 plasma screen and now need some advice on the audio front, as built in sound is apparently rubbish.
To explain my setup, the TV will be mostly using either the built in FreeView or video from my computer. I have an ATI HD5770 graphics card, which will be connected to the plasma screen by HDMI.
My questions are as follows:
• Apparently the PK590 screen can add some delay to the video from processing so audio going directly from the PC to the AV receiver will be a little out of sync. It would seem the way round this is to attach my PC, Xbox etc. directly to the plasma, and then use the plasmas optical out (which is automatically be adjusted to match up with the screens video) to the AV receiver.
This seems simple enough but I just wanted to check that the 5.1 video files I play on my PC will have that 5.1 audio sent thought the HDMI cable to the Plasma, and then also by optical cable to my AV receiver and off to my speakers?
• Seeing the costs of these AV receivers has been a bit of a shock for me and so initially I won't be able to purchase decent complete set of 5.1 surround sound speakers.
My solution to this is simply purchase two decent bookshelf speakers (or even use a cheap pair I have here for the time being) and slowly add on the extra speakers as I get the money.
Another alternative is to just cut of the connectors to a cheap 5.1 Logitech PC speaker set I currently have. Is it possible to do this? Again it will be a temporary solution until I can afford something decent but would at least give me some surround sound rather than just having two cheap bookshelf speakers.
• The only thing I can see myself really needing for the AV Receiver is one headphone output, and two optical inputs - one for the plasma, and one from my PC when I just want to play music without the plasma on.
Will the
cheapest AV Receiver from Richer Sounds be good enough for the job, or will I notice much better sound by spending a bit more? If so what would you recommend?
I have a nice pair of Sennheiser HD555 headphones so I'll only really be listening through my speakers when I have friends round or watching a movie with surround sound.
Many thanks for any advice you can give, I can assure you it will be greatly appreciated!
