15-12-2003, 3:52 PM
#1 (permalink)
pre-outing
I have just built up an av system of pioneer 434 plasma, ax5i amp, 868 dvd and dynaudio speakers
I want to run my cd player (rega planet) though my old aura hi-fi amp into the left/right dyn 72s wich gives better audio quality. I am told this can be done by "pre-outing" the amplifier.
Is this easily done? Is it best to also use the hi-fi amp to drive them for films as well, or revert back to the ax5i for that.
How do other people integrate their av and audio systems?
Help please
15-12-2003, 4:29 PM
#2 (permalink)
Thanks: Gave 6, Got 19
Take the main L & R Preamp (line level - usually phono (RCA) sockets) output signals from the ax5i and feed into an Aux input pair on the hi-fi amp. Use the hi-fi amp to drive the speakers.
You'll have to determine a volume control setting for the hi-fi amp when used with the ax5i to get the levels balanced, and reset to that each time you want ot show a film.
Then you can just select between the CD player or the Aux input on the hi-fi depending on what you want to hear on the main speakers.
Assuming, that is, that the hi-fi amp has enough power to give you the levels you need for film.
AVR300+P90/MA GR20+GRC/M5ds/StrataIII,
PT AE3000, Beamax 293cm diag 2.35:1 M-series screen, BDP550, Arcam CD93, Harmony 1000 RC
15-12-2003, 4:41 PM
#3 (permalink)
can i then control the hifi volume though the ax5i for films?
maybe i'm better off having a speaker switch and running the two am[ps and sources completely seperately??
many thanks
15-12-2003, 4:45 PM
#4 (permalink)
Thanks: Gave 5, Got 30
Your volume contorl of the ax5 will change the volume of the front pair at the same time as the other speakers (it will pass a louder signal to the hifi amp if you increase the volume of the av amp). follow davekh's advice & you'll be fine
There's someone in my head but it's not me.
Panasonic TH37PX60, Sky HD, Denon 2200, PS3, Onkyo 805, Kef iQ5, Kef iQ6c, Kef Q Compacts, Kef Egg , MJ Acoustics Reference 100
15-12-2003, 5:02 PM
#5 (permalink)
does that have any adverse on the sound quality when watching films?shouldn't it be better because i'm using a proper hifi amp on the l/r speakers?
15-12-2003, 6:28 PM
#6 (permalink)
It doesn't have an adverse effect on SQ for films on my setup. Mmmm does it sound better? don't think so - certainly not noticable
15-12-2003, 6:57 PM
#7 (permalink)
Conspicuous Member
Thanks: Gave 153, Got 1,013
I am currently doing the same thing with my Cyrus 8 amp. I use it only for two channel use but for movies I have the preouts from my AV amp going into it. I don't think it sounds any better for DVDs with or without the stereo amp but it's certainly not any worse. I just set the volume on my Cyrus 8 amp to 12 'O' clock when watching DVDs as that is where the volume was when I configured the AV amp with it connected.
15-12-2003, 8:04 PM
#8 (permalink)
Conspicuous Member
Thanks: Gave 14, Got 447
As mentioned by others, the sound for DVD is going to be much the same with or without a HiFi amp connected.
The reason for this is because the part of the AV amp that lets down the sound for CD etc is the pre-amp and not (normally) the actual amplifacation. When watching a DVD you still use the AV amps pre-amp, but for CD this is not.
Mark.
Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Sony BDP-S500 > Lumagen VisionHDP > Panasonic TH-46PZ85B. Marantz RC9200
