Denon and the Sky HD HDCP Problem.
Old 30-05-2010, 3:53 PM   #31
Thanks: Gave 29, Got 77
I had this when I got my 4310 on Thursday and had me head scratching for a bit. Since then have upgraded the firmware so need got retest.
Old 28-06-2010, 10:33 AM   #32
New Amstrad DRX895 and Denon 2310
Hi All,
I've just upgraded my Sky HD box from an old Thomson to a new Amstrad 895 and hitting the HDCP issue (at least I think so). I'm continuing to use the HDMI 1 port but not seeing any picture.
I do see the SkyHD boot image but no picture afterwards. I switch back to the Thomson and all is well. If I connect the Amstrad directly to the LCD TV and it works fine.
As an aside, I used the new Amstrad box with an old CRT TV via Scart and I don't get a picture there too. Should I be able to use scart to get a SD picture?
Old 01-02-2012, 1:23 PM   #33
Thanks: Gave 90, Got 53
Hi has this issue been resolved yet ?????
As an getting it ATM on my new AV amp with SKY HD
Old 13-02-2012, 4:46 PM   #34
Thanks: Gave 417, Got 91
out of interest what amp are you using?
Old 13-02-2012, 5:28 PM   #35
Hi mate its a denon 3312
link here
http://denon.co.uk/UK/Product/Pages/...ductId=AVR3312
CatManDo (13-02-2012)
Old 13-02-2012, 5:49 PM   #36
Cheers just wondered, I am getting intermittent problem with my Denon 1912 and Sky HD.
Never had a problem with my 1909 but got a new TV now also.
Will see how it goes, don't want to but may end up connecting Sky HD straight to TV and not Amp.
Old 13-02-2012, 5:51 PM   #37
hi mate what sky box you got 1tb HD box .......
its a common issue Denon not doing much about it they waiting for sky ......
seems a cop out to me from denon
Old 13-02-2012, 5:58 PM   #38
Yeah its the Sky HD 1TB box.
Bit of a pain, the screen flashes a ferw times with the Sky HDCP error but eventually comes on!
I want everything fed through my Denon, don't really want to put it straight to TV.
How have you got around the problem mate?
Old 13-02-2012, 6:11 PM   #39
Year i know what you mean i other amp had no issues at all it was a sony AV amp........but this amp and sky dont get on everything else is fine
I dont a a error message just black screen for a few secs ...
but its good some days no issues all some days it plays up it depends on what channel am watching on sky i think ......
only answer atm is try another brand off amp ,,
I prob get yamaha amp next waiting to send my amp back as Denon have no answer atm either
Old 17-02-2012, 5:10 PM   #40
paulr2006's Avatar
Thanks: Gave 954, Got 1,552
Just for information i'm having the same issue intermittently with my Yamaha RX V671 (Great Amp.) most of the time it's fine then it will start losing sync, blank screen etc. Unplug HDMI cables a few times usually fixes it ok.
HDMI leads are decent quality & I have tried substitutes, Superfi swapped the Amp. but same thing with the new one.
Connect direct to the TV no problem!
Old 17-02-2012, 6:13 PM   #41
Hi thanks for the tip are you using a SKY HD box. But I don't see the point of having a av amp with Hdmi if am plugging direct into tv
Old 23-02-2012, 9:47 AM   #42
I've had to cable mine straight to the TV.
Bit of a pain as I now have no On Screen Display from the Denon when watching Sky.
Old 25-02-2012, 12:52 PM   #43
paulr2006's Avatar
Yes Sky HD If you have to plug the Sky box direct to the TV you can at least still benefit from the Amp. due to 5.1 DD via optical or coaxial as Sky HD does not pass this signal via HDMI.
Update:
Despite several substitutions of latest version high speed HDMI cables I had this issue, however as I wish to add a HDMI splitter to another TV I bought a further HDMI cable & decided to try it, nothing special price wise (£9.95 for 3 Metre) & the problem has gone away! I can only conclude that despite reasoning to the contrary all HDMI cables are not the same in some way!
Old 25-02-2012, 12:54 PM   #44
Update:
all HDMI cables are the same as far as i know mate....as they are digtial ....
does yours happen all the time as mine is very very intermintent ....
some days nothing .....
very strange .....
Old 25-02-2012, 1:04 PM   #45
paulr2006's Avatar
very strange .....
Yes, I agree all HDMI cables are supposed to be but it would appear not in my case.
Yes mine is intermittent, however I have tried swapping the cables back & without inserting the HDMI lead several times it does not work, however the new cable works first time every time?
Old 25-02-2012, 1:09 PM   #46
ok mate thanks for letting me know i have tired a few hdmi cables no joy there you must be lucky .......
thanks for the tip thou
Old 25-02-2012, 1:23 PM   #47
I am using hdmi 1.4 official Panasonic cables and get the problem still....
Old 25-02-2012, 1:32 PM   #48
Yep am using 1.4 3D Sony cables no joy there either ........
Old 16-03-2012, 7:24 AM   #49
Thanks: Gave 3, Got 3
I have just ordered a Denon 2312 and have now come across this thread, which gives me cause for concern. I have a Sky HD Pace box which I intend to connect to the av amp with HDMI and optical.
Anyone got this working? ..... if so what brand of hdmi cable are you using (though they should all work the same way)?
May cancel the order and look for another receiver. I don't want to go back to connecting hdmi to the TV.
Old 16-03-2012, 10:09 AM   #50
Nope no fix mate think twice before you buy but it mainly effects the new sky HD box so they say
Old 16-03-2012, 10:17 AM   #51
RSRAVI
You have the Denon 3312. What make and model of Sky HD box are you using?
Old 16-03-2012, 6:00 PM   #52
Originally Posted by HenryPorter View Post
RSRAVI
Sky DRX895 Sky+ HD Box 1TB BOX mate ,,,,,
Old 16-03-2012, 6:47 PM   #53
OK - reading this thread there are people who
- have changed their hdmi cable to get it to work
- have got it to work on an old Thomson Sky HD box
- have experienced the same problem with a Yamaha av amp connected to their Sky box (with the same hdmi cables)
- are having the problem with the 1Tbyte Sky box.
Looks more and more like it is a problem with a specific Sky box type and certain hdmi cables.
There is a whole other avr 2312 owners thread on here with people raving about this amp, and who are using a Sky HD box successfully. My Sky box is a Pace model (not 1Tbyte), so I am going ahead and ordering the Denon amp. If I experience the problem I can always send it back, but I suspect that this is affecting a very few, unlucky, people.
Old 16-03-2012, 7:17 PM   #54
ok let me know how you get on you got link for 2312 thread please
Old 16-03-2012, 7:24 PM   #55
Denon AVR-2312 - Owners' Thread
Hope this link works.
Old 18-03-2012, 11:22 AM   #56
Thanks: Gave 0, Got 2
I have the Denon 2312 and a Sky 1tb Box with this issue, usually it's not that bad maybe 1 or 2 flashes every 5 minutes but I'm just watching the F1 HD channel and the picture is going off completely every minutes and flashing constantly.
I've tried several combinations of ports and HDMI cables but nothing resolves it.
I have noticed the problem occasionally when using my Xtreamer, the sequence and speed that the Tv / Denon, Xtreamer is turned on seems to cause that but not matter what sequence I power sky on it doesn't help.
Old 18-03-2012, 11:53 AM   #57
Hi its def the amp cos when i plug my old AV amp Sony 2400ES i have no issues at all .........
Only thing that changes is the AMP ...
Denon or Sky need to bring a update out to sort this out i think ...and Now too ....
Old 19-03-2012, 9:39 AM   #58
Spoke to Denon support this morning, they say they are waiting for Sky to release an update for the Sky Box.
Denon have shipped affected products to the Sky engineers who have acknowledged the problem is theirs and will release a update in the future to resolve the issue.
Hopefully Sky will support 5.1 over HDMI with the update to!
Old 19-03-2012, 10:04 AM   #59
Hi denon have said that for sometime mate sky won't be bothered about sorting that out
Old 19-03-2012, 12:38 PM   #60
I asked Denon why would Sky fix a issue that only affects their receivers and the response was that it was a problem with the Sky box so only they can fix it...
I'm not that bothered, Sky is going when I finish my 12 month contract in a few months anyway, the main reason we kept it when I moved house was for Sky+, no other recorder is quite as good for recording I found but now with access to all the iPlayers etc via Xbox, iPad etc my need for Sky+ is pretty much gone.
Other then the Sky+ problem the Denon has been great.
