Sony DA 4300es and Panasonic DMP BD30 NO TrueHd Audio ..HELP !
Old 28-07-2009, 10:29 PM   #1
1,620, Level: 9
Points: 1,620, Level: 9 Points: 1,620, Level: 9 Points: 1,620, Level: 9
I cant get the TrueHd Audio light on the receiver to come on.. I have the hdmi set up from the BD player to the receiver and bitstream is selected on the audio menu on the panasonic, no matter what bd disc I play, no light on the receiver.. any help is appreciated.. 5.1 surround
Old 29-07-2009, 7:49 AM   #2
IL Cattivo's Avatar
4,749, Level: 16
Points: 4,749, Level: 16 Points: 4,749, Level: 16 Points: 4,749, Level: 16
Activity: 14.4%
Activity: 14.4% Activity: 14.4% Activity: 14.4%
Thanks: Gave 88, Got 152
Re: Sony DA 4300es and Panasonic DMP BD30 NO TrueHd Audio ..HELP !
Page 21 of the Pana DMP BD30 manual fella....
You will probably need to turn BD-Video Secondary Audio to OFF within the Digital Audio Output Settings....
Old 29-07-2009, 12:26 PM   #3
1,620, Level: 9
Secondary audio is an has been off
Old 31-07-2009, 10:47 PM   #4
1,620, Level: 9
Still cant get this to work
Old 06-08-2009, 10:21 PM   #5
2,542, Level: 11
Points: 2,542, Level: 11 Points: 2,542, Level: 11 Points: 2,542, Level: 11
Thanks: Gave 4, Got 0
I have this same problem with my BD 30 but i have the Sony DA 2400es even went and bought a new HDMI 1.3b cable but no difference! can anybody offer a suggestion??
Old 07-08-2009, 4:15 PM   #6
IL Cattivo's Avatar
4,749, Level: 16
Activity: 14.4%
Just out of curiosity... If you select LPCM output via HDMI on the BD30 does the amp display Multi-Channel with the Blue light illuminated on the front when playing HD audio?
Old 07-08-2009, 4:26 PM   #7
34,323, Level: 45
Points: 34,323, Level: 45 Points: 34,323, Level: 45 Points: 34,323, Level: 45
Activity: 99.7%
Activity: 99.7% Activity: 99.7% Activity: 99.7%
Thanks: Gave 78, Got 2,504
LPCM lights up. You do not get an HD audio format indicator when streaming LPCM to the receiver. You don't get one with any receiver.
Old 07-08-2009, 4:40 PM   #8
IL Cattivo's Avatar
4,749, Level: 16
Activity: 14.4%
Ummmm... I know that dante Thank you..
I am asking them the question to these guys hoping they will repond with the answer.. 'Yes, the Blue Light is illuminated and LPCM displays on the front panel' or 'No it doesn't...'
Just trying to eliminate whether these guys have problems with their Blu-Ray players as apose to their amps....!!!
If they are Bitstream'ing thier HDMI audio with Secondary Audio turned off from their BD30's then their players seem to be having issues sending the lossless audio formats to the amp to decode, or the amps are not decoding the signal at it's end properly to illuminate the HD indicators.... (Do you know of any Bitstreamig settings on the SONY amps that might be restricting these signals dante..?)
Might be a good idea to see if you guys can take your players to a friends house who also has an A/V reciever (HDMI) with the HD codecs onboard to see if the problem still persists....
Process of elimination by the looks of things maybe!
Old 07-08-2009, 7:25 PM   #9
2,542, Level: 11
Hi ukbladerunner, the blue light does light up when the player is set to LPCM, i'm going to try the firmware on the player and see if there are any updates which might help, when the player is set to bitstream and i've set the audio on the disc to True HD it only shows on the amp as Dolby Digital 3/2.1
Thanks for your help by the way!
Old 10-08-2009, 3:45 PM   #10
2,542, Level: 11
Hi Guys, thought i'd let you know once i updated the firmware on the player all the HD audio indicators on the amp lit up! success!!
Old 10-08-2009, 8:04 PM   #11
1,620, Level: 9
Hello,, when I have the BD30 set to PCM,, the Blue Light is on on front of the Sony Receiver and it show AFD Neural THX then it says Dolby Digital 3/2.1,, then it says Linear PCM 48kHz.. I have the Panasoni player set to True HD Audio..But nothing on the receiver show TrueHD.. I appreciate your assistance.. i have updated the firmware on the DVD player..
Old 10-08-2009, 8:42 PM   #12
32,978, Level: 44
Points: 32,978, Level: 44 Points: 32,978, Level: 44 Points: 32,978, Level: 44
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 286, Got 1,331
If you have it set to PCM, you won't get HD audio to light, you need to set it to bitstream.
Old 11-08-2009, 3:36 AM   #13
1,620, Level: 9
It is on bitstream,, still no trueD light
Old 10-09-2009, 7:16 PM   #14
1,620, Level: 9
Still cant get any of the HD Audio signal lights to come on on the receiver.. anyone?? It is set to bitstream
Old 10-09-2009, 8:35 PM   #15
1,311, Level: 8
Points: 1,311, Level: 8 Points: 1,311, Level: 8 Points: 1,311, Level: 8
Thanks: Gave 1, Got 33
join the club, i have a bd60 and an onkyo 507.
using the stones shine a light blu ray, which only has two options on sound, dts hd or true dolby.
still cant get the hd or true dolby to light up, same as you, bit stream out and secondary audio off.
i have tried every permutation of settings, no joy...
hooked up the bd60 to tinternet and downloaded latest firm ware, still no luck......
Old 10-09-2009, 8:39 PM   #16
1,620, Level: 9
SEA - Using that BR disc,, since it only has two audio options,, does that mean you get no audio at all??
Old 10-09-2009, 8:45 PM   #17
1,311, Level: 8
no i get audio, but only the dts light is coming on .
pressing the audio button on the bd60 remote shows dts hd or dolby true.
the onkyo does not appear to be decoding it....
Old 12-09-2009, 12:00 PM   #18
1,620, Level: 9
that is my exact same problem
Old 12-09-2009, 7:10 PM   #19
1,311, Level: 8
update, just recieved a new bluray through the post, will smith legend,only one soundtrack, true dolby hd.
no luck, still cant get any of the lights up on the 507.
in fact am on my second 507 (thanks to the guys at richer sounds preston) and still the same.
down loaded latest firmware for the bd60, 1.9, turned off viera link, nada, zilch....no joy.
reading through the posts there was conflict between panasonic players and certain av receivers ?
bottom of the page my week old 507 has developed a problem with the transformer.
when it gets hot starts buzzing like a good un, bad enough to cause the top case to rattle.it can be heard from across the room.
the 507 is going back, to be exchanged for a sony or denon, if i can batter the other half into submission it,s the denon, £439 at r/sounds.
hopefully will have better luck with a different make...
Old 09-10-2009, 6:54 AM   #20
1,399, Level: 8
Points: 1,399, Level: 8 Points: 1,399, Level: 8 Points: 1,399, Level: 8
I have a Panasonic DMP BD60 and a Onkyo 607 with the same problem. Using Bitstream but no TrueHD or DTS-HD and I have confirmed all the settings are correct numerous times. The Onkyo 607 continues to display Dolby Digital and DTS while in Bitstream and multichannel when I select PCM on the BD60. Just updated the firmware in the BD60 yesterday. I was beginning to think I was the only one until I saw this post.
Has anyone had any luck correcting the issue? I do not have another device that I can test Bitstream TrueHD or DTS-HD and there is nothing left for my to test on either the Onkyo or the BD60.
Andre'
Old 09-10-2009, 2:07 PM   #21
1,311, Level: 8
I spent 45 minutes on the phone to Panasonic, the A/V help line. with the help of Dominic (big thanks) i turned every thing off unplugged all hdmi leads and started again, while on the phone.
Settings on BD 60 confirmed as correct, Veira link off on tv and blu ray player, still no luck, lights on 507 still not lighting up.?
As i said in previous post my 507 developed a fault with the transformer and was changed for a Denon 1910.
Denon installed and still no HD lights coming on.
Saw the post on here that the Range were selling Sony BDP 350 for £109 + PP and bought one.
Set up and running in less than 10 mins and whooopee do da, little blue light on the Denon confirming HD audio.
The BD60 has been returned to Play.Com, they refunded on to my card this morning.
Still no wiser why the Onkyo or Denon would not display HD audio with bitstream output from the BD60
Old 09-10-2009, 6:15 PM   #22
1,720, Level: 9
Points: 1,720, Level: 9 Points: 1,720, Level: 9 Points: 1,720, Level: 9
Thanks: Gave 0, Got 27
Great news! Enjoy your weekend viewing with HD audio......
Powered by
 Latest popular product prices
Pioneer A209R
2 prices from
 £154.99 Click to show/hide the offers
Pioneer A209R
2 prices from
Pioneer A307R
3 prices from
 £182.54 Click to show/hide the offers
Pioneer A307R
3 prices from
Pioneer A109
1 price
 £99.99 Click to show/hide the offers
Pioneer A109
1 price
Onkyo A-9155
1 price
 £145.44 Click to show/hide the offers
Onkyo A-9155
1 price
 Updated February 9th at 6:30am. Prices include delivery.
