Hello,
First post here in the forums, but this site and its people have helped many times before.
I am having a problem with a setup.
I own the following:
Panasonic 58PZ850U 58" televeision
Onkyo 7.1 HT-S5200 home theater system
Motorola Verizon DVR (7000 series i think)
Sony Play station 3
My setup:
Sony PS3 and DVR connect to Onkyo reciever (both via HDMI)
Onkyo reciever connects to Panasonic television via HDMI out
My panasonic tv is connected to the onkyo with (white/red) audio out
My issue:
I would like to play ps3 games in 5.1 surround sound if not 7.1
My onkyo reciever does HDMI pass through to the television
So from what i have read so far it does not touch the audio and passes it to the television, from the television i pass it back to the reciever with the (red/white) audio cable.
On this page
PS3™ | Audio Output Settings
I am told that
"When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings]."
Am i understanding this correctly that i am only recieving 2ch sound through my hdmi cable passing through my reciever then to my tv back to my reciever?
I purchased an optical cable but here is my dilemma i only have one optical cable, if I:
REPLACE the (red/white) audio from panasonic tv to onkyo reciver with the new optical cable
will the ps3 hdmi, connected to the onkyo, pass through hdmi to the panasonic tv, outputting through optical to the onkyo output in 5.1? Does optical have the ability to ouotput in 7.1?
from what my tv manual says
"You can enjoy your home theater by connecting a Dolby Digital (5.1 channel) decoder and “Multi Channel” amplifier to the
DIGITAL AUDIO OUT terminals.
Caution
Depending on your DVD player and DVD-Audio software the copyright protection function may operate and disable optical output.
External speakers cannot be connected directly to PROG OUT terminals.
When an ATSC channel is selected, the output from the DIGITAL AUDIO OUT jack will be Dolby Digital. When an NTSC
channel is selected, the output will be PCM.
When playing movie on SD Card Movie player, when the sound has been recorded in Dolby Digital, the output from the
DIGITAL AUDIO OUT terminal will be Dolby Digital. When the sound is recorded in the other formats, the output will be PCM."
or will i have to connect the optical deirectly from the playstation3 to the onkyo system and bypass the panasonic television itself?
One reason i think it best to be from the television would be so that my Motorola DVR also outputs to the speakers in 5.1.
I hope someone can assist me with this and that i havent made it too complicated. Thank you!
