dear Forum
I was hoping for some fairly straightforward advice based on the following, bearing in mind I've never had a speaker set up before, and only ever used a TV speakers (yes, I know
I would like at minimum 5.1 surround for my living room.
The space is approximately 10ft by 12ft.
I have the following equipment which would all need to be processed by any receiver / amp:
- Panasonic 37PX80 Plasma
- Sony PS3 for BluRay and DVD playback(HDMI)
- Xbox 360 (HDMI)
- Wii (Component)
- PS2 (SCART)
- PVR recorder (Some cheap 160gb Wharfedale Unit) (SCART)
I have the ability to pump audio over optical from the PS3 and the Xbox 360.
What would people recommend? Im not even sure what would be a sensible budget, to include speakers?
FWIW I dont deal well with cables, so the rears I would like wireless speakers if someone can recommend some decent ones.
Thanks so much for any advice, you can be sure its appreciated.
