23-12-2008, 10:11 PM
#1 (permalink)
| | Member
Thanks: Gave 110, Got 26 | Should i buy a power amp for my Onkyo 905, or is it a total wast of ££´s
Hi All.. Should i Buy a Power Amp for my Onkyo 905.... or is it a total wast of ££´s...
I have just got the XTZ 99.36 floor models, and im thinking of buying a power amp to conect to the fronts for better Musik exp, i know the cinema exp is quite good and i do not feel like i lack power, but is this upgrade whortwile effort and is the ££ spent wisely...??
Cause im reading and reading in thise forums, and im never satisedfied, yes i like my setup but im wondering if this is the new way to go, lol im upgrade Sick i know, prob like some of you guy´s
And i have never had a pre+power combo before
Then i could in time sell my 905 and buy a prosseser unit, but im splitted down the middel, if it a go or a no no...!
In thise finance time i could get a bargin on the clasifeides or a demo unit...
What should i look for in terms of Amps brands, and how much power do i need to beat the 905 ( i know its not only the power ), and to keep me happy when i do get a pre quality unit... we just need new model comming out then there s a barging there too i know, i don t care about scaling if the units have though im more than happy...
So fellow member what should i do , and if its worthwile what brands /models should i look for.. budget will be maby up to 500-600£ but lower prefered.
This is my own conclusion, i had the Audiolab 8000p/m in my sights.
23-12-2008, 11:30 PM
#2 (permalink)
| | Member
Thanks: Gave 8, Got 112 | Re: Should i buy a power amp for my Onkyo 905, or is it a total wast of ££´s
Someone posted here a few weeks ago the comment that there was little difference between using internal or external amplifiers with Onkyo AV amps - that was put down to the quality of the pre-amp/processor stages.
There is a separate issue - it's quite difficult (impossible?) to find reasonably priced processors that have all the facilities people have become used to from modern AV amplifiers.
24-12-2008, 9:34 AM
#3 (permalink)
| | Senior Member
Thanks: Gave 138, Got 115 | Re: Should i buy a power amp for my Onkyo 905, or is it a total wast of ££´s
So if Onkyos aren't the best to pair up with an external power amp due to their pre-amp/processor stages, are there any makes which would be worth doing this for?
Denon, Marantz, Yamaha...?
__________________ Screen TH42PHD8 Sources Sony BDPS350, Marantz CD50SE, ProJect Debut 2, BT Vision Amps Denon 2309, Rega Cursa, Rotel RB985mk2 Speakers Rogers LS4a, Dynaudio 42C, Wharfdale DFS20, BK XLS200DF Cables Mark Grant, Van Damme Red, QED Silver Anniversary. Flickr |
24-12-2008, 10:45 AM
#4 (permalink)
| | Veteran Member
Thanks: Gave 243, Got 538 | Re: Should i buy a power amp for my Onkyo 905, or is it a total wast of ££´s Quote:
Originally Posted by Phlog Someone posted here a few weeks ago the comment that there was little difference between using internal or external amplifiers with Onkyo AV amps - that was put down to the quality of the pre-amp/processor stages.
There is a separate issue - it's quite difficult (impossible?) to find reasonably priced processors that have all the facilities people have become used to from modern AV amplifiers. | That was probably me
At the time I was using the 875 as a Pre and an Arcam P7 as a power amp. I couldn't tell much of a difference with or without the power amp attached.
In retrospect I think thet was a lot to do with the speakers I had at the time (M&K LCR850s). Despite their reputation they don't need as much umph as the XTZs do which are around 3-4db less sensitive than the 850s.
I decided to have another go with the 875 as a Pre and bought a Cinepro 2K6. Now this is in a different league to the Arcam and the hungrier 99.36s really made use of the extra power on tap.
The Cinepro really opens up the bass from the XTZs as they are being given almost unlimited power and they really deliver a punch that wasn't quite their with the 875.
My personal opinion is that the Onkyo processing isn't 'great' but it still does a good job but you will have to spend quite a bit before you can really improve on the 905s internal amps.
If you look at the specs on a lot of stereo power amps or mono blocks they generally deliver more current per channel than a similiarly rated multichannel amp. If you really want to spend more money, I would be inclined to get seperate amps for the front 3 or a stereo amp for the L&R.
Good setup and sub integration would probably be my first priority before additional amplification though. How did you get on with REW etc.?
Adam
__________________ | Fujitsu P42XHA58EB | BD HTPC | SkyHD | Squeezebox Duet | Beresford Caiman | Onkyo TX-SR876 | Parasound Halo A23 x 3 Bi-Amped Fronts & A52 Surrounds | XTZ 99.36 & 26 | M&K CS22 & Xenon 36 | SVS AS-EQ1 | Behringer EP2500 & DIY Dual Drive AE AV15-X Subwoofer | |
24-12-2008, 11:20 AM
#5 (permalink)
| | Senior Member
Does that mean that you could pair up any AV Surround amp that has pre-outs with a separate power amp and expect some improvement in performance over using it as an "all in one" box, then? Or are some better suited than others to this? Either due to better processing, or whatever?
24-12-2008, 1:04 PM
#6 (permalink)
| | Member
Thanks: Gave 110, Got 26 | Re: Should i buy a power amp for my Onkyo 905, or is it a total wast of ££´s Quote:
Originally Posted by theo cupier Does that mean that you could pair up any AV Surround amp that has pre-outs with a separate power amp and expect some improvement in performance over using it as an "all in one" box, then? Or are some better suited than others to this? Either due to better processing, or whatever? | yes , the smaller resivers i the leauge of Denon 17-19xx and maby ohter simalir,but whit good prossesing, i thnik there is a big difference to be achived.. but when the amp puts out 220~140 multi Ch like the 905 , then i wasent sure, but i think its a interresting debate... and im hoping to get more replys, and recomondation on brands of power amps than i should look after 2 nd hand...
Angel . nope havent had the time to play whit the Rew yet (have a sike girlfirend som can play that loud and not sweep tones....!! but she is getting better..  , but willl get around it before i do buy a power amp.. and the current you talking about, is it the "amp" ~40, so when big power is nedded, in big movie scenes or komplex musik is there in a jiffy.
is this enughf to better the onkyo, a
Linn AV 5105 Power Amplifier or 2 : 240 mono bloks..!?
24-12-2008, 2:12 PM
#7 (permalink)
| | Veteran Member
Originally Posted by theo cupier Does that mean that you could pair up any AV Surround amp that has pre-outs with a separate power amp and expect some improvement in performance over using it as an "all in one" box, then? Or are some better suited than others to this? Either due to better processing, or whatever? | Any Receiver's pre-out stage is never going to be the same quality as a dedicated processor, as it is not a primary feature. However I wasn't implying that the Onkyo was any worse or any better than another brand's Receiver. I doubt there is much difference and it isn't the sort of feature that gets reviewed.
A seperate power amp will almost always give improvements to the sound reproduction, the question is can you hear it with your speakers and if you can, is it worth the extra cost? In the case I cited the £3k or so of Arcam P7 was absolutely not worth it, so I sold it and bought a better sub which absolutely was worth it.
If you haven't properly integrated your speakes and sub you may find that £500 spent on an SMS-1 (assuming it is required) may be money better spent than £1000 on a power amp.
What I am trying to suggest is that a decent power amp like a parasound or audiolab may well improve things but perhaps not as much as some other upgrade.
Adam
24-12-2008, 4:13 PM
#8 (permalink)
| | Senior Member
Thanks for the perspective.
What I'm trying to add is DTS-HD and Dolby True HD capabilities to my system and ideally some form of video switching (if not upsampling/upconversion) due to a deficiency of HDMI ports on my plasma.
I'm limited to DD/core DTS from my S350 BD player at present due to the lack of HDMI on my amp. I did contemplate going the analog out route with a S550, but the lack of bass management etc put me off.
I figured that properly managed DTS would probably be about as good as partly managed DTS-HD from the player (but still not as good as bitstreaming to the processor via HDMI) and I could save a few quid on the player that way.
So, if I can add DTS-HD and some video switching to my system - with something like a Denon 2808 - for only a few £00 and leave the power amplification to my Rotel 985 (and the stereo processing to my Rega) then this might be a good stop-gap until the dedicated processor market has a few more options for HD.
I realise the processing won't be world beating, but it should be better than DTS core via coaxial and if I'm leaving the stereo sources to my Rega processor I don't need to worry about the stereo performance.
Does the logic seem reasonable? Or am I just wasting money that I should put straight into one of the current HD audio dedicated processors?
24-12-2008, 4:50 PM
#9 (permalink)
| | Member
Thanks: Gave 8, Got 15 | Re: Should i buy a power amp for my Onkyo 905, or is it a total wast of ££´s
I owned a Denon integrated av amp and was very happy with it. Later I had the opportunity to buy a Rotel power amp and hooked the two up together.
The improvement was so striking I spent the best part of an afternoon plugging and unplugging the two, just to appreciate the enormous difference it made.
Just my tuppence worth.
regards
Parmenion
All back of the bus........
25-12-2008, 8:35 PM
#10 (permalink)
| | Member
Thx for all the replys, this is still on the drawing bord, som any opionions would be great..
Im looking at the Aodiolab 8000p and m , and Nad M25 (don t know 2nd hand sale price on thise.) and the nad t975, it any of thise not wort wihle..
26-12-2008, 7:58 PM
#11 (permalink)
| | Member
Thanks: Gave 1, Got 6 | Re: Should i buy a power amp for my Onkyo 905, or is it a total wast of ££´s
I use a denon 1908 and an arcam p1000. The difference after adding the arcam was staggering, like going from a home theatre in a box to a proper hifi set up. Obviously the price difference between the two is very big so that's hardly surprising. If you're using a fairly decent av amp, it might be wiser to go for a stereo power amp, as you'll get much more for you're money. The surround effects will not benefit as much from a superior power amp, but you'll really hear the difference with music.
26-12-2008, 11:11 PM
#12 (permalink)
| | Senior Member
Thanks: Gave 11, Got 331 | Re: Should i buy a power amp for my Onkyo 905, or is it a total wast of ££´s
Ive had a 905 since the first month they were out. I looked at the power ratings and thought it would be more than enough, as I was moving house, getting a much larger living room, and taking the opportunity to upgrade my rig.
Anyway, the first day I was trying to get near reference level in my (albeit very large) living room, it would just get driven into thermal cut out....there wasnt enough real power to drive my AG Ref 3.1s I run up front. But then when you really investigate the "220w/p/ch" rating, it turns out to be one channel at limited range ...in reality the 905 really has about 120w pch at 20-20 all channels driven...the usual bull.
The only reason I upgraded was that I needed a lot more real power to drive the speakers (themselves rated 350rms continuous) enough to excite the room. So anyway, Ive got 2 x 3 channel Artcoustic power amps, giving me 2 x 700wrms channels for the fronts and 4 x 400rms for the rest - sorted, more than enough, and I really noticed a difference in how the speakers were driven
I wouldnt say it sounds "better quality" though - after all, a good power amp shouldnt taint the music IMO, it should just be neutral. The sound of the system is a combination of many other things, especially the source and the processing. I will probably upgrade the 905 to a more "high-end" box...but as others have mentioned - trying to find one that ticks all the boxes for convenience and features that you get with the Onkyo is pretty difficult right now, regardless of price point - so im holding fire ....maybe Arcam will do one once their new reciever has been out a while...we'll see...but before I splash out £2K upwards on a new processor, I want to hear a difference !
so in short - I wouldnt be upgrading power amps on the Onkyo unless you need more power. Otherwise, upgrade both at the same time and go for a higher end pre/pro when they are available - not much out there right now though
cheers, bogie
26-12-2008, 11:23 PM
#13 (permalink)
| | Member
sorry to say i do not have the dogh for at pre + power new.....
Anyone heard of thise : Denon POA-4400A
i found watts specs from 150-180 watts in 8 ohm , but i do not know the real one..
RMS into 8 ohms from 20 Hz to 20 kHz with no more than 0.02% total harmonic distortion 250 W (4 ohm, DIN 1 kHz)
Dynamic power: 400 W (at 4 ohm); 600 W (at 1 ohm)
Total harmonic distortion: Less than 0.002% (-3 dB at rated output, 8 ohm)
Inter modulation distortion: Less than 0.002%; (60 Hz/7 kHz: 4/1 at rated output, 8 ohms)
Power band width: 5 Hz - 80 kHz (8 ohms, THD 0.03%)
Frequency response: 1 Hz-300 kHz + 0, -3dB (at1 W)
Input sensitivity: 1 V (Normal in); 1 V (Balance in)
Input impedance: 25 k ohms
Output impedance: 0.1 ohm (1 kHz)
S/N ratio: 123 dB (IHF, A-weighting)
Output terminals: Speakers A or B 4 ohm~16 ohm; A+B 8 ohm~16 ohm
Will 2 of thise do any difrence, or should i look more around for new models , audiolab 8000p /m or is thise same or better leauge... i think i can treade somthing to get thise for free almost...
Could i set thise to 4 ohm and will my speakers manege that...?? or isent that the way it works.
27-12-2008, 10:03 AM
#14 (permalink)
| | Senior Member
it dosent work like that - you cant set your speakers to 4 ohm
in simple terms, what im saying is that if you dont require more power than the Onkyo will give, there is no reason to upgrade the power amps at all.
You dont say why you are not happy with the Onkyo? It is a very good integrated solution, certainly great VFM, and you will struggle to get anything that "sounds better" with the same features without spending many thousands of pounds (if at all right now)
If you are looking for an upgrade strategy, like buying power amps now, then upgrading the processor lately, then you really need to spend quite some cash to get better too im afraid. I would probably look at spending at least the same on power amps, as the whole Onkyo - so Id spend £1400 or more over here on a good 5 channel power amp ...in fact Id go for monoblocks or seperate amps - fitting 3 good high-power channels of amplification into a box that can be racked up is hard enough IMO
Im a similar position myself, so have im always looking at this, and right now, for my needs, I havnt come across another processor that will do all the features I want, as well as sound significantly better than the Onkyo ....so the Onkyo will stay for the forseeable future
cheers, bogie
27-12-2008, 12:26 PM
#15 (permalink)
| | Member
no not the speakers, but the mono bloks...... if you can set them at 4ohm, the ill get 400watt, and the speakers can handle 4 ohm.
Thx again , if anyone have opionions then share them whit me, im all ears...  |
