Originally Posted by Rob100 Yes, but it doesn't "convert" HDMI PCM audio to the analogue output. |
I was reading up a very good review of the Toshiba HD-XA2 HD-DVD player by Audio Video Revolution and came across this very interesting bit of information. From page 1:
As of this review you can count commercially available receivers or AV preamps that can decode either of these new formats on one hand, but the HD-XA2 features onboard decoding of Dolby TrueHD and Dolby Digital Plus and then outputs the analog signal via the player’s multi-channel outputs thanks to the player's high-performance SHARC® DSP digital-to-analog converters, or output multi-channel linear PCM via the HDMI output. With the HDMI 1.3 connector, the player will be able to send the encoded bitstream audio signal to Dolby TrueHD-capable next-generation receivers. However, I found a nifty device by PureLink that can extract out the Dolby TrueHD soundtracks without the player having to do the decoding and send it to a non Dolby TrueHD-decoding receiver. More on that later when I discuss HDMI switching.
And even further, from page 2:
Searching for an alternative way to effectively switch HDMI, I installed a PureLink HS-42A 4-in x 2-out HDMI switcher. The coolest feature of this box isn’t the fact that it effectively switches HDMI. This is currently the only box that can actually digitally strip out the high-res soundtracks from HD DVD and Blu-ray players that are using the HDMI output and convert it into optical or digital coaxial audio to run into your receiver or AV preamp. As I stated earlier, the player can decode and output these audio tracks via multi-channel analog outputs, or digital audio via the HDMI cable in linear PCM, but this PureLink box strips out the high-def audio tracks and sends them to any multi-channel AV receivers. Only a few receivers are available currently that support HDMI 1.3 and the Dolby TrueHD and DTS-HD formats. Onkyo is one such company, having just released the TX-SR605 receiver. However, the HS-42A switcher is able to strip the high-res soundtracks and decode them into linear bitstream, so you can enjoy the new Dolby and DTS formats without having to wait for capable AV receivers to be released on the market.
If this does what the review states it does, i.e. it can output the hi-def audio tracks via the coaxial or optical outputs, then that would be a better alternative than the Zektor MAS7.1 . For those interested in reading the review, here it is:
Toshiba HD-XA2 review
For further information on the HDMI switcher:
PureLink HS-42A
If the Purelink HS-42A does what is states it does, then there is no need to buy a new receiver / surround sound processor for a long time.
