Newbie question for new 5.1 system
Old 03-04-2007, 11:03 PM   #1
4,101, Level: 15
Points: 4,101, Level: 15 Points: 4,101, Level: 15 Points: 4,101, Level: 15
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 8, Got 7
Hey all.
I need a new 5.1 sound system for my X-Box 360, PC, TV & maybe DVD or freeview. I was looking at the all in one Lojitech Z-5500 but people are saying I migh tbe better getting a receiver and speakers for slightly more. Would it be worth it? The Z-5500 is only £200?
Cheers.
Old 14-04-2007, 6:43 PM   #2
3,535, Level: 13
Points: 3,535, Level: 13 Points: 3,535, Level: 13 Points: 3,535, Level: 13
Thanks: Gave 2, Got 5
Re: Newbie question for new 5.1 system
how did you get on? im in a similar boat.
Old 17-04-2007, 2:40 PM   #3
5,454, Level: 17
Points: 5,454, Level: 17 Points: 5,454, Level: 17 Points: 5,454, Level: 17
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 14, Got 54
You need to ask what you are willing to pay for the seperates first as if you are only willing to pay say £100 more for amp and speakers you won't get a good system even if secondhand for £300.
If you go the secondhand route a reasonable budget for an amp is £250 (older models of the denon 3803, 280? (any with dolby prologic 2) or pioneer 2011, maybe a 2014i if ur lucky. Then for the speakers (not including sub) to start you could go with the original Kef eggs 2005.1 at say £250 secondhand for a 5.1 setup. Then a reasonable sub rel quake at £180 or MJ acoustic 50 (maybe £150) or Kef 2500 sub is ok. Rel 100 so all in with wires to connect you are looking at £700 minimum for 5.1 speakers, sub, amp and wires to connect. So you need to ask is £500 more worth it? For me the answer is yes for you it may not be. Note this is just an example suggestion for a starter but good reasonable setup.
