Originally Posted by henry1234 Does anyone think that the basic dolby digital or DTS decoding from a quality unit such as the Lexicon or Meridian would outperform any of the higher bitrate formats decoded from a budget HD or BR DVD player and output from the 5.1 or 7.1 analogue outputs.
Source is very important I suppose and may outweigh quality issues within the new HD DVD player/decoder. Has anyone compared a new HD audio format with an old fashioned high end processor running plan old dd or dts? |
I have a Toshiba HD-A1 running HD-DVD, and an Arcam DV27 running SD, through a Parasound C2 processor. The quality of the HD audio is remarkable, whether it is sent by coax or analogue 5.1. With the coax input I believe the signal from the A1 (DD+ or TrueHD) is decoded to 1.5 Mbps DTS and this is
extremely impressive. In fact it is as good, to my ears, as DD+ through the 5.1 inputs at presumably higher bitrates (I think the C2 does a very good job of decoding). SD sources with standard Dolby Dig sound flat in comparison.
On another note, I just picked up a Lexicon MC-1, purely because it was bundled with the power amp I wanted. I have to agree with some of the comments above - this is still an awesome processor. It must wipe the floor with mid-range (and probably high-end) integrated AV amps. If the Meridian 568.2 is even better, this must be truly superb. However, the last 568.2s I saw went for a lot more than MC-1s, which seem to be bargains nowadays.
