Factory reset on a Primare SP31.7?
Old 31-03-2007, 4:30 PM   #1
3,356, Level: 13
Points: 3,356, Level: 13 Points: 3,356, Level: 13 Points: 3,356, Level: 13
Thanks: Gave 6, Got 7
Not as easy as the title suggests.
I have a secondhand Primare SP31.7. The previous owner has disabled the video output - so no onscreen menus and the IR remote has also been disabled. I got it through a dealer.
Is there a way to factory reset the SP31.7 from some physical button combination?
I've asked a few dealers and they all suggested speaking to the distributer on Monday.
Old 31-03-2007, 9:11 PM   #2
3,356, Level: 13
Re: Factory reset on a Primare SP31.7?
Sorted out now.
Old 02-07-2011, 7:34 PM   #3
ssuellid
I have the same problem with my Primare SP31.7 and need to do factory reset without using the menu which i cannot get into.
You sorted yours out ! Please how did you do it.....can you remember ?
