Millenium 2.4.6 DTS Decoder Error
Old 18-03-2007, 9:11 AM   #1
4,054, Level: 15
Points: 4,054, Level: 15 Points: 4,054, Level: 15 Points: 4,054, Level: 15
Activity: 0.5%
Activity: 0.5% Activity: 0.5% Activity: 0.5%
Thanks: Gave 37, Got 18
I have a Millenium 2.4.6 DTS decoder, that has been giving trusty service for 10yrs, hooked up to a Pioneer DV525 DVD player (8yrs) and a Pioneer CLD-D925 Laserdisc player (10yrs). All working beautifully.
The question/problem i have is as follows:
  • A friend lent me his Toshiba 360E DVD player to see what i thought, could not get a DTS signal out of it at all, the decoder would not lock onto the signal, regardless of the settings in the player.
  • I then picked up a Denon DV1720 last week for an install job elsewhere, and put it in my system to check functionality, by some coincidence i could not get a DTS signal out of that either.
I wonder if the later players have a different DTS signal from previous years?
Old 18-03-2007, 9:20 AM   #2
Illustrious Member
48,568, Level: 53
Points: 48,568, Level: 53 Points: 48,568, Level: 53 Points: 48,568, Level: 53
Thanks: Gave 884, Got 1,285
Re: Millenium 2.4.6 DTS Decoder Error
I binned mine a while ago as I could not get it to lock onto anything.
Old 18-03-2007, 4:19 PM   #3
4,054, Level: 15
Activity: 0.5%
thanks Nic for reply, do you know if it was an issue with the decoder or newer players?
Old 18-03-2007, 4:29 PM   #4
Illustrious Member
48,568, Level: 53
I could find nothing obviously wrong and put it down to old age. It certainly used to work with LD and DVDs and then didn't after a period of 'iffy' behaviour with the same material. It might be time to 'retire' an old friend I am afraid.
