RMB-1075 - Electical Surge Lights - Normal???
Old 08-03-2007, 8:30 AM   #1
15,505, Level: 30
Points: 15,505, Level: 30 Points: 15,505, Level: 30 Points: 15,505, Level: 30
Activity: 8.4%
Activity: 8.4% Activity: 8.4% Activity: 8.4%
Thanks: Gave 52, Got 102
Rotel RMB-1075 - Electical Surge Lights - Normal???
I have recently purchased a second hand rotel RMB-1075 av power amp. It has 5 lights on the front that according to the manual should only come on if there is a problem with one of the channels of amplification.
However, a few of them appear to come on everytime i turn the amp off. They stay on for less than a minute then go out. I haven't actually bothered as yet to see if its the same lights each time or not.
Is this normal, or do i have a faulty poweramp?
Steve.
Old 10-03-2007, 2:06 PM   #2
Ianfromnotts's Avatar
6,340, Level: 18
Points: 6,340, Level: 18 Points: 6,340, Level: 18 Points: 6,340, Level: 18
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 12, Got 169
Re: RMB-1075 - Electical Surge Lights - Normal???
mine do the same too so I wouldnt worry about it I havent
Old 11-03-2007, 12:35 PM   #3
15,505, Level: 30
Activity: 8.4%
Cheers, i also checked this out with the dealer, who confirmed it was normal
Old 15-03-2007, 8:02 PM   #4
16,519, Level: 31
Points: 16,519, Level: 31 Points: 16,519, Level: 31 Points: 16,519, Level: 31
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 89, Got 183
its normal
do they come on in like a "timed" pattern - mine do on my RB-985MKII
interestingly when I had it - another RB-985MK II (I did have two) - on switch off - they both lit up the leds in a different pattern/order
