Pioneer VSX
Old 07-03-2007, 11:06 AM   #1
Rob_Meister's Avatar
4,313, Level: 15
Points: 4,313, Level: 15 Points: 4,313, Level: 15 Points: 4,313, Level: 15
Thanks: Gave 80, Got 36
Question Pioneer VSX
Hi all, I'm looking at the following on Richer Sounds:
http://www.richersounds.com/showprod...d=PION-VSX1016
However, I'm not sure this is what I need. I believe the above amp is not capable of outputing all of the sources through one HDMI out, depending which source is selected.
The main thing I'm after really is the ability to plug my HD DVD player, Sky+, Xbox 360 and my future PS3 into an amp. All I then want going from the amp to my wall mounted TV is a HDMI lead prefrably. So I have less wires to channel through the wall. This is only for an 18 year olds bedroom so budget isn't as high as many home cinema setups.
But please any recomendations/advice appreciated.
