part required
Old 01-03-2007, 2:11 PM   #1
4,886, Level: 16
Points: 4,886, Level: 16 Points: 4,886, Level: 16 Points: 4,886, Level: 16
Thanks: Gave 1, Got 2
part required
I need some power transistors as my amp has blown it's right channel. I can find my transistir guide for the life of me. Two types in there labeled A1294 & C3855. Threy seem to be made by SK? Any ideas where i could source some or an equivalent? Thanks
Old 02-03-2007, 9:22 AM   #2
Nickiniquity's Avatar
2,520, Level: 11
Points: 2,520, Level: 11 Points: 2,520, Level: 11 Points: 2,520, Level: 11
Thanks: Gave 0, Got 4
Re: part required
Is that the entire code from the transistor? They are probably some hard to find Japanese transistors, but if you can get hold of some data on them, it is very likely that an equivalent could be subsituted. Could you post a photo (or PM me) and I'll see if I can help.
Which Amp is it? Are you sure that it is the actual output transistors which are blown. (have you checked if they are s/c or o/c etc)
Laters
Nick
Old 02-03-2007, 9:31 AM   #3
Senior Moderator
alexs2's Avatar
30,879, Level: 42
Points: 30,879, Level: 42 Points: 30,879, Level: 42 Points: 30,879, Level: 42
Activity: 32.6%
Activity: 32.6% Activity: 32.6% Activity: 32.6%
Thanks: Gave 388, Got 1,230
Re: part required
SK would likely be Sanken,a well known japanese semiconductor manufacturer.
The partial number given may also correspond to this transistor.
http://www.sanken-ele.co.jp/en/prod/...f/2sa1294e.pdf
Old 02-03-2007, 9:36 AM   #4
4,886, Level: 16
Re: part required
Hi Nick,
Amp model is Memorex STAV3100, i'm guessing the output trans are blown going by experince with these amps(right hand sound is quiet and muffled). I can't find any schematics and this was was by th enow defunct Tandy. Here is some pics.Many thanks,Dave.
Looks like one has been replaced before as part number is different.
Old 02-03-2007, 9:43 AM   #5
4,886, Level: 16
Re: part required
Looks like i've found them
http://www.signalsuk.com/Signalsuk.n...ePage?OpenForm
The A1491 one looks like it has been replaced with the wrong part-lower power rating.
Old 04-03-2007, 5:45 PM   #6
4,886, Level: 16
Re: part required
I also need a replacement remote control for this amp-any ideas?? Thanks
