Hi Rik...welcome to the AVForums.
As you'll find from other posts here re the Nautilus series B&Ws,you do need a good powerful amp to get the best out of your speakers,which present a fairly difficult load to many amps,especially in the LF region,where the speaker's impedance drops below 4 ohms for substantial periods.
This in turn requires a good current delivery from any amp you choose....you could look at the Krell 400i integrated,as well as possibly the Densen and Bow,which a number of other people recommend(my own choice would be the Krell,or the Bryston integrated,if you go down that route.)
Otherwise,you would need to be looking at a pre/power combination of not less than 100W/channel,and preferably able to easily double that into 4 ohms,and your best option there would be to look for either used or ex-dem Krell or Bryston amps,although the Krells probably will not fit your space requirements.
Another possibility is the range of Brystons designed for mounting on or near the speakers,with a suitable preamp.
It's worth mentioning also that you will find the 800 series are often auditioned with either of these brands,with which they work well,both sound-wise,and electrically.
