Sound format
Old 22-09-2005, 8:17 PM   #1
JT JT is offline
4,880, Level: 16
Points: 4,880, Level: 16 Points: 4,880, Level: 16 Points: 4,880, Level: 16
Thanks: Gave 14, Got 3
Sound format
Hi all
No idea where to post this so..............
Which should sound better, 96kHz and 16bit, or 48kHz and 24bit? My sound card will only use one or the other through my HK5500 and its difficult to do a sound test.
Thanks John
Old 24-09-2005, 1:18 PM   #2
9,504, Level: 23
Points: 9,504, Level: 23 Points: 9,504, Level: 23 Points: 9,504, Level: 23
Thanks: Gave 20, Got 73
The latter. In simple number terms.
Old 26-09-2005, 12:58 AM   #3
9,504, Level: 23
Are you sure you didn't mean 16/48 and 24/96?
