trading up to a better power amp??
Old 11-09-2005, 5:13 PM   #1
6,499, Level: 19
Points: 6,499, Level: 19 Points: 6,499, Level: 19 Points: 6,499, Level: 19
Thanks: Gave 4, Got 0
I have a Parasound 855a power amp.
My question is:-
Is it worth getting a 1205a or the 2205a?
i hear that these three sound the same as each other.
Can anyone help?
Old 11-09-2005, 9:55 PM   #2
9,504, Level: 23
Points: 9,504, Level: 23 Points: 9,504, Level: 23 Points: 9,504, Level: 23
Thanks: Gave 20, Got 73
Depends on what speakers you are driving?
Tonally i doubt there will be much difference but improvements in perceived "space, timing and soundstaging" maybe on offer due to more HP being on offer to your speakers,
Old 12-09-2005, 5:12 PM   #3
6,499, Level: 19
i am driving 5 m&k speakers.
Old 12-09-2005, 8:25 PM   #4
Conspicuous Member
recruit's Avatar
26,919, Level: 39
Points: 26,919, Level: 39 Points: 26,919, Level: 39 Points: 26,919, Level: 39
Activity: 8.1%
Activity: 8.1% Activity: 8.1% Activity: 8.1%
Thanks: Gave 521, Got 593
pras - what M&K speakers are you running ? also more power is always better than less so the 2205 is definitly a better amp and i know there are a quite a few members here running that particular amp.
Old 12-09-2005, 8:35 PM   #5
Senior Moderator
alexs2's Avatar
30,879, Level: 42
Points: 30,879, Level: 42 Points: 30,879, Level: 42 Points: 30,879, Level: 42
Activity: 32.6%
Activity: 32.6% Activity: 32.6% Activity: 32.6%
Thanks: Gave 388, Got 1,230
There's no doubt that the Parasounds are pretty much all decent amps,with a very good heritage,but it's not always true that more power is better than less,as that is very dependent on the quality of the amps(sound quality,not just build quality),and a look at many Japanese and US(esp studio based) creations of the 80s and beyond would prove.....bags of power,but awful sound.
I'm not saying that it applies to the Parasounds,but it isn't true for all amps that more power equates to better.
Old 12-09-2005, 8:38 PM   #6
Conspicuous Member
recruit's Avatar
26,919, Level: 39
Activity: 8.1%
Quite right Alex2 but we are talking about Parasound amps and not all amps in general..
Old 12-09-2005, 8:48 PM   #7
Senior Moderator
alexs2's Avatar
30,879, Level: 42
Activity: 32.6%
Which I think was what I said in my reply.
Old 12-09-2005, 8:58 PM   #8
Conspicuous Member
recruit's Avatar
26,919, Level: 39
Activity: 8.1%
no problem
Old 13-09-2005, 7:59 AM   #9
Thunder's Avatar
8,045, Level: 21
Points: 8,045, Level: 21 Points: 8,045, Level: 21 Points: 8,045, Level: 21
Thanks: Gave 12, Got 18
I have a 2205 driving my centre and surrrounds and its an outstanding piece of kit Yeah it dosn't have the subtelty of my Tag monoblocs but then it retails at about 2k for five channels and the Tag monos used to be 2k each! I must say it has bags of current and its sound is detailed but with a sledge hammer like force
Can't recommend it enough
Old 13-09-2005, 8:21 PM   #10
6,499, Level: 19
well at the moment i am running 5 x lcr 55. i have a parasound 855a but i feel that the sound quailty would be the same as the 2205a. i personally think it wont be worth upgrading to it.
any ideas on that?
Old 13-09-2005, 8:32 PM   #11
rags's Avatar
10,985, Level: 25
Points: 10,985, Level: 25 Points: 10,985, Level: 25 Points: 10,985, Level: 25
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 24, Got 54
With those speakers I would agree with you - the 855 probably drives them well enough. You dont need a 2205.
Old 14-09-2005, 6:37 AM   #12
Conspicuous Member
recruit's Avatar
26,919, Level: 39
Activity: 8.1%
any ideas on that?
With them speakers the 855a is probably enough if you were thinking of upgradeing to bigger speakers then it might be worth considering an upgrade but i would stick with you have got for now.
Old 21-09-2005, 12:26 PM   #13
6,602, Level: 19
Points: 6,602, Level: 19 Points: 6,602, Level: 19 Points: 6,602, Level: 19
Thanks: Gave 10, Got 13
My halo A52 poweramp is way to powerful for my Quad 21L's. I think even parasounds lower powered amp are very powerful.
CaM
Old 23-09-2005, 1:03 PM   #14
6,499, Level: 19
even though the parasound is 85 watts per channel, its way better than the mavssive all in one 170 watts per channell ones. its diffently better than my old power the rotel 985 (100w per channel)
