6 channel Power Amp Advice
Old 03-09-2005, 7:36 AM   #1
16,519, Level: 31
Points: 16,519, Level: 31 Points: 16,519, Level: 31 Points: 16,519, Level: 31
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 89, Got 183
Just a quick query really - I've a Pioneer 2011 which I think is absolutely superb - best sound steering I've heard - but sometimes find the amplification a bit lacking (quality wise - although all relative)
Would a Power Amp upgrade to something like a Rotel RB985 be worthwhile - or would I not really notice a difference unless I went for a higher model ? Its hard to judge how the Power amp stage of the Pioneer would compare to something like the 985
Thanks for any help
Mark.
Old 03-09-2005, 8:43 AM   #2
skinnyfat
Posts: n/a
The Rotel power amps are superior to the pioneer's, not only in 'real' power, but current delivery, construction, components, transformer, etc. etc. which will translate into better sound quality, stability etc etc. So in short, yes you will notice a difference
Old 03-09-2005, 8:44 AM   #3
16,519, Level: 31
Activity: 1.7%
Ta - thanks very much Skinnyfat - its just you see the 985s going reasonbly cheap now (250 odd) - so seems a worthwhile not too expensive upgrade
Mark.
Old 03-09-2005, 3:12 PM   #4
Dfour's Avatar
9,915, Level: 23
Points: 9,915, Level: 23 Points: 9,915, Level: 23 Points: 9,915, Level: 23
Thanks: Gave 30, Got 74
Moving to processors and power amps.
Old 03-09-2005, 9:45 PM   #5
3,527, Level: 13
Points: 3,527, Level: 13 Points: 3,527, Level: 13 Points: 3,527, Level: 13
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 25, Got 29
Try the Rotel RMB1066 if you acn afford to spend a bit more (around £400-£450 second hand or £600 new) and don`t be put off by the conservative 6x60W. Its a lovely amp.
If you are looking for something cheaper the older Rotels are very good value for money.
