Using both Front and Rear for Stereo
Old 24-08-2005, 2:02 PM   #1
geoff66
Posts: n/a
does anyone know of a unit that can run both front and rear speakers together in stereo mode? I don't mean in pro-logic or in an 'effect' mode. It would be good to be able blast a CD out using say 4 amplifier channels and really get the place shaking!
geoff
Old 24-08-2005, 2:06 PM   #2
Conspicuous Member
Jase's Avatar
21,876, Level: 35
Points: 21,876, Level: 35 Points: 21,876, Level: 35 Points: 21,876, Level: 35
Activity: 9.1%
Activity: 9.1% Activity: 9.1% Activity: 9.1%
Thanks: Gave 74, Got 417
Quite a few AV Amps/Receivers now have 5CH/7CH Stereo Modes. All they do is duplicate the Front Left and Right channels out of the Surround Left and Right and Surround Back Left & Right speakers. The centre channel gets a mono mix of the two.
Old 24-08-2005, 3:40 PM   #3
6,151, Level: 18
Points: 6,151, Level: 18 Points: 6,151, Level: 18 Points: 6,151, Level: 18
Thanks: Gave 10, Got 0
Any ampwith A+B speakers outputs
Old 24-08-2005, 4:00 PM   #4
geoff66
Posts: n/a
but with A+B you are usually sometimes limited by the combined impedance of the speakers. I assume that using 4ohm speakers could result in a 2 ohm load
Old 24-08-2005, 4:03 PM   #5
geoff66
Posts: n/a
Also as I do not want to re-plug the speakers, using A+B wouln't I have to wire the speakers to both rear & B output terminals?
Old 24-08-2005, 9:14 PM   #6
geoff66
Posts: n/a
Jase,
Thanks - i'll checkout some of the newer AV units
geoff
Old 25-08-2005, 12:41 PM   #7
Reiner's Avatar
13,567, Level: 28
Points: 13,567, Level: 28 Points: 13,567, Level: 28 Points: 13,567, Level: 28
Thanks: Gave 2, Got 13
Yamaha does have DSP modes called 'Disco' and 'Party' that come close.
Ok, so it is an effect mode but at least you don't need to re-wire the speakers.
Old 25-08-2005, 12:52 PM   #8
5,467, Level: 17
Points: 5,467, Level: 17 Points: 5,467, Level: 17 Points: 5,467, Level: 17
Thanks: Gave 1, Got 0
A simple mixer will do it, with one input (L&R) and two outputs, to 2 Amps.
