Originally Posted by la gran siete |
In general,the ability of an amp to double its power into decreasing loads etc has a lot to do with good power supply design,and in turn,providing the output stages with voltage and current that dont fall dramatically as the load impedance falls,and power demands increase.
In some amps,this is provided by relatively massive transformers,with oversized reservoir caps etc,and in others,massive regulated supplies and so on....Chord adopt a slightly different approach by using switch-mode supplies,but again the answer is a very stable,high current power supply,which equates to a lot of cost,whatever the solution.
A lot of modern amps are capable of either doubling output into 4 ohm loads,or at least going a good way towards this,but very few will do so into 2 ohm loads or less.
Being honest,a lot of those old Japanese receivers and amps were capable of good power into reasonable loads,but really struggled when the going got rough,although many were beautifully made.
One that springs to mind was an Accuphase design rated at 100W with(for the late 70's)amazingly low distortion figures etc,but it sounded awful....very flat and sterile,and really didnt like reactive loads.
My(rather long winded)point is that really good,high powered amps are rarely cheap,and a lot of that cost is in the power supply.
