Is Arcam AV8 processor better than Rotel 1098?
Old 28-07-2005, 6:14 PM   #1
Sab Sab is offline
7,255, Level: 20
Points: 7,255, Level: 20 Points: 7,255, Level: 20 Points: 7,255, Level: 20
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 60, Got 7
I currently have a Rotel 1098 processor and it good but I now have the chance to buy a secon hand Arcam FMJ AV8 for a goodd price. Is it worth buying the AV8 considering it is nearly 3 years old? The main difference between them is that the AV8 is THX Ultra2 certified but the 1098 is not and the Rotel has quite a large TFT display but the AV8 does not.
To be honest both are good but I think the AV8 is better.
Old 29-07-2005, 1:38 PM   #2
13,799, Level: 28
Points: 13,799, Level: 28 Points: 13,799, Level: 28 Points: 13,799, Level: 28
Thanks: Gave 536, Got 296
Thought I'd give this a bump as I'd like know as well.
Old 29-07-2005, 6:21 PM   #3
CYRUStheVIRUS's Avatar
4,882, Level: 16
Points: 4,882, Level: 16 Points: 4,882, Level: 16 Points: 4,882, Level: 16
Thanks: Gave 3, Got 8
I have heard both and the Arcam was the more impressive.
That said , i heard the Arcam with the seven channel power amp and B&W 800 SERIES and the Rotel with only a 1075 and M&K K series.
Difficult one to answer.
Old 30-07-2005, 8:38 AM   #4
Sab Sab is offline
7,255, Level: 20
Activity: 0.7%
They are both good but I have been told that the Arcam AV8 sounds better thn tha A32 stereo integrated amp (1200 pounds) in stetero and What Hifi - if you believe them - said that the Rotel 1098 sounded as good as a 750 pound stereo amp.
The Arcam AV8 is about 850 pounds more - list full price- than the Rotel 1098 so should be better anyway.
Old 30-07-2005, 12:34 PM   #5
Audionyx's Avatar
4,513, Level: 15
Points: 4,513, Level: 15 Points: 4,513, Level: 15 Points: 4,513, Level: 15
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 0, Got 21
I used to own the Rotel 1098 and upgraded to the AV8. The AV8 is slightly better for movies but is in a different league when it comes to analogue.
There are rumours that the AV8 is soon to receive a much needed software update with rather tasty hardware modifications in the near future
Old 02-08-2005, 11:17 AM   #6
7,211, Level: 20
Points: 7,211, Level: 20 Points: 7,211, Level: 20 Points: 7,211, Level: 20
Thanks: Gave 0, Got 6
The 1098 has had a IIx upgrade available for over a year now!
