Originally Posted by grazy Sorted! well I have found the culprit! I have a AC RYAN media player/streamer connected via coaxial (worse player ever DO NOT BUY ONE!). I unplugged the coaxial and the hum is gone!
Has anyone got a suggestion on how I stop the media player from doing this? Do i need to earth it or stop it from earthing? |
Unfortunately, you probably can't stop such a device (you admit yourself - IN CAPITALS), so you need to isolate it. Whilst fiddling around with earthing might remove a hum, it also might end up burning the house down or electrocuting members of the family - so don't even consider such dangerous actions. Especially as the fix is trivial.
If the media player has an
optical output, use that. The optical cable acts to break the electrical ground loop.
If not, get yourself a simple coax - optical convertor such as
this or
this.
