Originally Posted by recruit It's a little more complicated than just DAC's, if you think about HiFi you are isolating different sources and this is what I am doing, I am making the best out of what I have got for 2 channel audio, as I said earlier the preamp stage in the AV888 is stunning and by using an out board DAC I have more flexibility and isolation of electronics which do the jobs that they are specified to do.
The DAC's in the AV888 are superb and probably more than enough for most people, but I am trying to squeeze every last bit of performance I can out of my 2 channel listening experience, I have a Squeezebox Touch which feeds High Resolution Audio into the DAC and then I use my highly modified Oppo BDP93 also into my DAC for CD playback via COAX which I cannot do with just the AV888 alone as I would have to keep going into settings each time and changing them from analogue to digital.
If I get the new Super DAC from ARCAM then I should expect an even bigger jump in performance, the bottom line is that the AV888 can be treated as as high end HiFi preamp stage as well as processor for Multichannel audio too. |
I am glad you are using coax spdif digital out from a disc spinner. It seems to me that this is still a very good option for high end audio, if not the best today.
I have experimented as part of my AV system for 2 channel system with the following alternatives :
iMAC, Macpro on battery, with and without numerous programs the upload onto ram (Pure sound etc, etc), solid state hard drive, the Linn streamer, for me the old CD spinning is still better. I have used Lindeman, Marantz, Denon, Audio Note and niam transports, plus naim, Weiss, Tron, DacMagic, Rega, Bryston, Arcam dacs at home and four different power supplies for the DAC Magic.
The DAC plays only part in the DA process, the commonly quoted influence on the DAC sound is 1. Analogue output stage, 2. Powers supply, 3. DAC itself
