Originally Posted by AngelEyes My understanding is that you are running out of gain not watts, so you are experiencing signal clipping not amp clipping.Can you raise all the channel levels by 5 or more dB so you have more range on the volume control?
Adam  |
Thanks for your reply, yes low level gain is the problem, but doesn't the gain of the power amp allow me to recover this?
Looking at the specs of my amp (Parasound HCA1205a 140W@8Ohm) the input sensitivity is:
1 V for 28.28 V, THX Reference Level; 1.2 V for full output
The next model up of the same generation is the HCA220, 220W@8Ohm the input sensitivity is:
1 V for 28.28 V, THX Reference Level; 1.5 V for full output
Doesn't that mean that driving the bigger amp with the same max input voltage gives me 220W?
Otherwise that implies that if your driving a 100W amp @ 1.5V and bought 1kW Krell you could still only get 100W out of it unless your preamp could put out 15V?
